Had a busy couple weeks with the Alaskan LX, she got a brand new set of Nitro 5.29's in frond and rear axle, rebuilt the knuckles, went through all 4 hubs and cleaned and re set them up, addressed a Ujoint that was a little soft and finally got some test drive/break in miles on her. Yesterday I pulled the front section of the transfer case to address the front output seal and bearing.
After everything done, I have now developed a rattling fluttering mechanical gear to gear sound when the powertrain is spinning around 45mph and faster and most apparent right at that sweet spot between acceleration and coast. If you're on the throttle, its smooth and quiet. If you are coasting (zero throttle) it is smooth and quiet. If you are at highway speeds and just maintain speed, there is a distinct high speed vibration.
Drive shafts are in good shape, brand new diffs, I am confident everything front and back of the transfer case are not contributing to this. Pretty sure the inner guts of the transfer case are gracefully exiting...through the drain plug.
So, Question: How likely am I to have good success rebuilding this T-case? Are parts still serviced to replace gears and all of the 1 time use snap rings? Or should I start shopping for a used lower mileage unit? Or just fill mine with some 80w140 to quiet it down and send it?
For the record, as mentioned in my other thread..... I love the 5.29's with the 315's!! Except on the highway.. heh heh
Hope to get this new issue addressed and start shopping for 37's
