Fitting tow hitch help
Kent England
I purchased a second hand tow hitch and need some advice on the fitting please, I can see that on the tow hitch frame there are 6 holes, and another 4 holes in the plate near the hitch.
Does the plate with the 4 holes just bolt onto the face of the fender?
Also the holes that are in the frame work, do the bolt to the chassis of the car underneath, do you put bolts right through the box section under the car or are holes in the sub frame threaded?
Also need help with the wiring, do you just buy a socket with the wires that fit the LC?
Any help would be appreciated as I need to fit it this weekend. Thanks.
Forgot to add the photo in first post
Here is the photo of the tow bar
You don't mention what year and type of vehicle.
I have a '97 LX450. I have a similar hitch. The 6 holes on the sides will match up perfectly with pre-drilled holes on the frame. I don't have the middle bracket.
Does your hitch have a 7-pin harness? The U.S. models have the 4-pin.
Hi Ranger.... Its a 4.5 petrol 1996
are the 6 holes in the sub frame of the car threaded? its to dark here at the moment to see, I can see the holes at the bottom of the frame, but it feels like they are not drilled right through, do they have to be drilled right through and long bolts put in?
It has the 7 pin harness
The 6 holes on the bottom of the frame, as well as the 4 holes on the back of the crossmember should all have captive nuts welded on the inside.
It's possible yours are plugged up from years of dirt and grime.
ahhhhh thats great to hear that they have captive nuts inside the box frame :-)
I take it that the 4 holes that bolt into the back of the fender, two are tapped and two are clear holes that you would put through bolts through?
Are all the holes 12mm 1.5mm threads?
Mick
I thought that the 4 on the back had captive nuts as well, but I'm not 100% sure on that.
Not sure on the size, some searching should net you results.
Two with captive nuts, two without.
nothing between the plate and the cross member with the 4 holes in. That looks like a witter tow bar and you should probably have some spacers to go between the side brackets and the chassis to clear some welds?
Each side there is a packer with 2 holes in for the rear most holes and another with just one in for the front hole. They hold the bracket clear of the cross member corner brace welds and are literally just bits of plate with holes in. They need to be the right thickness to make the holes in the plate that connects to the centre of the cross member line up and I think they're 8mm but I couldn't check that for you till tomorrow night.
EDIT: looking at your pictures again, you can see where the packers were on the side brackets by the rectangles of different colour around the holes.
You may want to put some tow hooks on them as well. Just to be on the safe side.
Fitted the tow hitch today, was a bit of a struggle with a few problems.
Left hand side had captive nuts, but right hand side only the hole nearest the front of the car was captive, had ro remove the rear quarter righthand side fender to be able to put the nuts on the bolts.
Made up and fitted some 1/4 inch plates as suggested by wildsmith, def needed them.
With a bit of pushing and shoving it all ended up bolted on :-)
The electric socket that was on the hitch in old and no good, need to get a new 7 pin socket, while under the car, I see there was a wiring loom running across the width of the car and looks like it is the loom for the rear light clusters, in the midde of the loom there is a socket, is that the socket that you can plug in the tow hitch wiring?
Here in the UK toyota do not now sell that bit of kit to plug into that socket, any suggestions on what I can do to sort out the wiring?
Here in the US, there is a company that makes plug & play wiring kits. I don't know if they would work for you but someone in Europe may do the same thing.
http://www.hopkinsmfg.com/twkits.html
Good Luck,
Paul
