Put in my first locker this past week, a new ez locker bought off of a board member, never installed.
At the same time, I did a 55/mini/60 front knuckle conversion, with a wardens adapter/83 mini booster/ 94 4 runner master combo. Don't know if this is relavant. I do not have it all adjusted yet, but it is bled.
Question is this:
Is it normal to have everything turn much harder after reassembly? I figured yes, since more (well, larger) parts were moving. I can hear it ratcheting when I turn a tire.
The passenger side will slightly move the drivers tire, then will ratchet and turn by itself, both move in reverse. The drivers side only moves itself, ratchets olny, never moves the passengers. Is this normal? Install went pretty well, the thrust washers looked new, adn the rear end has maybe 40K on it orig, so they were reused.
I am having a tough time adjusting up the rears, since everything turns harder. After 10 years open, I got pretty good at adjusting the rears for feel, but this is a different feel altogether.
Thoughts?
Question is this:
Thoughts?
