Greetings Mudders,
I bought this FJ60 (my first) back in Aug 2012 and have been hooked ever since. It's a roughly stock 60, silver (i guess grey with age now), 143K. I don't believe any of the drive train has been rebuilt. Rust isn't too bad AFAI can tell. Frame has surface rust and body has some spots but no holes. I'm not sure if I have a lift, perhaps someone can tell - Ironman shocks.
Pics: http://imgur.com/a/tpMdi#0
Since I bought her I've been doing a bunch of basics, using this forum (and FSM) as my bible - a huge thanks to all of you - it's incredible how useful your posts have been, even old stuff. I'm a novice mechanic, in fact this is the first rig I've ever touched with tools. So bear with me as I'm learning slowly but surely. I've done a bunch of things but here's a highlights list:
- knuckle rebuild including wheel bearings on driver side to fix inner seal leak using marlin crawler kit
- oil galley plug drilled out, tapped and fixed with allen plug and jbweld (no leaks!)
- fixed carb fan, which was causing slow "hot starts" since i got her
- brakes all around, including new wheel/brake cylinders in the drums. Fixed a pesky frozen ebrake system too (new cable, unseized bellcranks, etc)
- fixed crooked steering wheel by adjusting relay rod
- replaced charcoal canister per this post. Vac leaks I could find.
- basic fluids and filters swapped
- FJ62 mirrors thanks to the guys at Torfab
Plans:
- I have a rebuilt carb that I want to install, hoping to improve MPG. I may do the valve cover and manifold gaskets at the same time. Maybe desmog... not sure yet as it looks intimidating.
- Rust. I'm currently working on rust removal/prevention. I've been wire wheeling the frame, permatex rust treatment, followed by epoxy paint to seal. I know I'm not getting the inside of the frame... but I don't have the know-how or space for a frame-off job.
I'm not really going to crawl her, I'm using her for camping and hiking, getting into trouble on forest service roads, etc. I'd like to get her a bit more fuel efficient (currently 11.5 mixed / 14.5 hwy). I'm curious based on the pics and what I've mentioned here - what else would you guys prioritize on this rig? Looking at the pics, anyone see anything glaring that I should address?
Thanks a lot, and I hope to get to know some of you better over time.
-- Vic (in Seattle, WA)
Plans:
