First Cruiser - what to do first?
Hey -
Just picked up my new cruiser and can't wait to start building this thing up! After doing some homework on this forum (thanks all) I feel like a got a good one... '94 with factory lockers, great leather interior, great motor with only 107K miles.
So - what should I do first? It's completely stock from the ground up (except maybe the tires and keyless entry).
Clayton
What you do for mods will likely depend on where you are at and how you view it's purpose. These trucks can be great family movers stock and can be modified out for rock crawling, expedition use, or a bit of all.
Baseline it first though and be sure to check those brakes. Some of these trucks will eat brakes if the PO or cheap place put on cheap pads. Inspect everything closesly and check the torque on the big bolts that hold the thing together.
Have fun with it. I've started to have the most fun with mine since I decided resale value doesn't matter and I'm never selling it. It lets me do to it what I want to. Lots of options out there, you just have to decide what you want to have it set up for.
Oh, and Welcome! :flipoff2:
I had a full service done on it first thing including front & rear diff fluid changed. But although the coolant system had been flushed by the PO and the T-Dealer check it all out a couple weeks later I had overheating problems. Probably the reason the PO had it flushed. Anyway the radiator was 90% clogged so really have them check out the cooling system well. You may want to re-build the fan clutch. That is the one thing that stops these vehicles, COOLING COOLING COOLING. Especially with the summer knocking at the door.
Baseline the T belt, all fan belts and all fluids. Check the brakes. Drive it a couple of months or more until you know if there are any issues. Have fun.
Kalawang
