Finished Brake Lines (pics attached)
Discussion in '40- & 55-Series Tech' started by UNO_RACING, Mar 5, 2007.
  1. UNO_RACING
    UNO_RACING
    776
    Apr 19, 2006
    Well I finally finished plumbing my brakes. Initially I was going to lay the steel lines down, but decided to go for the braded lines throughout the brake line. Just couldn't spend the time bending the tube and mucken it up.
    Total cost of the brake lines was $275.00 with all the fittings. Cost of one New Castle while installing $1.15, time saved undetermined, but lots. Cost of easily installing brake lines in 10 min, priceless.
    Enjoy!
  2. UNO_RACING
    UNO_RACING
    776
    Apr 19, 2006
  3. reservefj40
    reservefj40
    92
    Apr 15, 2004
    Georgia
    Looks awesome.
    I have to redo mine and was dreading bending all those tubes. Never thought about doing it that way. Where did you get the lines and fittings?
  4. TimCFJ40
    TimCFJ40
    134
    Media:
    1
    5
    Sep 11, 2006
    Auburn, AL
    Looks Great. I'll be interested to see how mushy the pedal feels with all of that flex line installed. I've always been told to minimize flex line in a brake system to get a good firm pedal feel. Let us know how it turns out for you.
  5. mr_manny
    mr_manny
    1,655
    12
    Apr 10, 2004
    san pancho, ca
    x2
    a good quality flare-tool makes it easy...
  6. UNO_RACING
    UNO_RACING
    776
    Apr 19, 2006
    I too was worried about the pedal feeling spongy but I was assured by the tech who builds them is that they are much more superior than standard brake lines. Essentially they are reinforced tubing (not sure of material) wrapped with braded steel. I'll let you guys know tha outcome...
  7. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    14,871
    3,480
    Mar 15, 2003
    Sacramento, CA
    Making the hard lines is suprisingly easy and cheap. You can get a 25 foot roll of tube and 16 fittings for $35 from Classic tube. Getting a double flare tool to work is a bit of a chore, but easily mastered in an hour. Your set up looks nice and cleanly done, but bending up brake lines is nothing to fear.
  8. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    Absolutely! Brake line is cheeeeep, so if you futz it up, NBD. Its just another skill to learn. Same principles apply to hard lines for fuel. I bought a double flare tool, made in the USA, for about $27 and have never done one that leaked or didn't work, not one.
    Anyway, what you did should work, but your pedal has to be a little spongier than steel.
    Ed
  9. UNO_RACING
    UNO_RACING
    776
    Apr 19, 2006
    For a little more reassuance on the line type, I checked my Volvo's lines and all of them are rubber. I have huge Brembo brakes too.
    In addition, I also contacted my mechanic buddy and he too assured me that the set up will work---better than stock. His rational was that they are teflon pipe wraped in stainless steel and then again with a rubber coating. The lines are is specific to brake applications.
    I'm still a little leary, but a little more confident that it will work out okay.
  10. El Cazador
    El Cazador
    595
    1
    Sep 24, 2005
    SoCal
    I'm such a cheap bahstard I'll bend steel first. Did it as a complete novice on the '67 Bronco I rebuilt before this FJ40 project and nothing leaked at all.
  11. mr_manny
    mr_manny
    1,655
    12
    Apr 10, 2004
    san pancho, ca
    I think you'll be ok, a buddy also went the flex-line route for his buggy...of-course he doesn't drive it around town...
    If you ever get a chance, I would recommend making a hard-line.
    You will be surprised how easy it is...
    options are always good.
    manny
  12. Hobbs
    Hobbs
    477
    10
    Nov 13, 2005
    Big Pine, CA.
    That much flex-line makes me nervous......
  13. 1phrogguy
    1phrogguy SILVER Star
    852
    64
    Feb 14, 2006
    Woody P
    what is that sticking out of the prop valve with the wire on it? Is it an electronic prop valve?
  14. VTFJ40
    VTFJ40
    632
    Jun 16, 2004
    Northern Vermont
    SS Flex line for brakes is nothing like regular rubber lines. It's some tough stuff. Sponginess shouldn't be a problem.
    Pricey, but whatever works for you.
  15. idus25
    idus25
    227
    Sep 3, 2006
    St. Louis, MO
    Where did you purchase the lines and fittings? Was this a universal kit?
  16. UNO_RACING
    UNO_RACING
    776
    Apr 19, 2006
    I designed the kit myself and had a manufacture build it. Took them 15 miniutes to build. You have to have a special tool to mount the fittings.
    The way I designed it was with 1/4" nylon string, a pen and note pad.
    I laid (no pun intedned) out the sting to accomidate for the angles (more angles results in more length). I then mad a visual observation of the angles in the line to determine what fittings I needed.
    Took my note pad along with the string to the manufacture--- and bada bing it was done in no time.
    I just got off the phone with the manufacture for a testament.... The line that I have is specifically designed for high peformance brake applications. To name a few; off road applications (baja trucks), drag cars, sprint cars, and circle track cars, etc.
    The internal line is made of teflon...its then wrapped in stainless steel and then sleaved with a high pressure plastic sheeting.
    If you are interested in the kit, send me a PM. The hose is $5.00 a foot and the fittings range from $.50 to $10.00. I'll chagre a handeling of $25.00 for my time..you pay truck...
    I accept pay pal too!
    Late,
    UNO.
  17. Trollhole
    Trollhole THC Supporting Vendor Moderator
    20,797
    Media:
    79
    Albums:
    4
    2,632
    Mar 6, 2005
    Mauldin, SC
    Have all braided lines on the rear of my 40 with disks.. I wouldn't want the brakes to be any quicker than they are now.
  18. UNO_RACING
    UNO_RACING
    776
    Apr 19, 2006
    It's an electronic sensor in the event that the porp valve is loosing pressure, the dummy light will activate on my dash.
  19. UNO_RACING
    UNO_RACING
    776
    Apr 19, 2006
    Hello everyone.
    Yesterday I finally had the opporutnity to bleed my brake lines and clutch line. All I can say is that there is not an issue with soft pedal. In fact, the pedal feels perfect (very little play, but just enough).
    I ran synthetic fluid throughout the system. Started bleeding with my buddy at the passanger rear wheel and worked our way around. It was a time consuming process, but we got all the air out of the lines.
    IMHO, the lines are worth the money. Makes a nice clean install.
