After cleaning I added some additional sound and heat sheeting. Monday it goes to get bedlined. Just spray out to clean!
Can't wait for the pics!
Do you have any pictures I am wanting to add the sound & heat sheeting but I was worried if I put some of it down and then put the bed liner over top I wouldn't get a good seal??? Maybe I am over thinking it though?
Depends on what you put down. You shouldn't have any problem with the thinner/stiffer stuff, but I wouldn't expect to add jute or anything similar.
I'm planning on lining mine with Second Skin Spectrum, then going over that with bedliner. I'm hoping that it will dampen it enough between the two. If the Spectrum doesn't do a good enough job on it's own, I may add some Damplifier or something similar over it.
so, in re to this rear heater I saw on a thread "un-plumbing of rear heater" it seemd complicated w firewalls, hard lines, more hoses etc. I don't want to mess up my front heater or cooling systm. Is it ok for me just to remove this rear heater and the hoses that connect through the floor board and leave the rest as is?
Ebagg you can chime in too (as if you needed permission, HA!). Its pretty simple, there are only two hoses to disconnect from underneath, the electrical connector from on top of the unit in the cab and a few screws/nuts. The foam insulation you can replace. There will be a hole in the floor, hence the need to replace the foam insulation after you access the area. 1/2![]()
You also have to cap off or reconnect the disconnected hoses, or you'll be buying an engine pretty quick![]()
Make sure you call Ant at Spectrum to confirm the drying time of the Spectrum prior to the bedliner. IIRC he told me this product is water based which could take a couple of weeks or more to dry out. He was adamant about letting it dry out prior to spraying anything else over it, obviously.
I believe Spectrum is dry to the touch within 24 hours but like Jack said it can take weeks to fully dry. I would suggest laying the spectrum a good month or longer before covering it with liner just to play it safe.
Already aware of it, and planning on letting it dry for at least 30 days. Probably longer than necessary, but it won't hurt anything to have me stepping on it for a while.
