few would appreciate...
Removed the lines going to my rear heater. A real pain and still have scars on my hands from trying to get the hard lines out. I think the only way to do it easily would be to do it with the Cats removed.
So, if you don't care to remove all of it, I would recommend to just put heater hose between the two lines right under the heater unit to let the coolant circulate from one to the other. But if you have a good way to cap each end that would be just as good. The last sections coming into the heater are hose, not hardlines so would be as simple as undoing the clamp on each and substituting a single piece of hose (long enough to make the u-turn).
I bypassed mine at the firewall and simply left the metal tubes in place. If I've ever got the exhaust out I might take a stab at removing the pipes, but until then they can stay where they are :eek:
Definitely the right strategy 96r50
I'm not sure necessarily if "few will appreciate" what you are doing....
I will say that I do this every year to my truck--gut the entire thing, clean, and reassemble. The only difference this time has been that I am re-bedlining my truck currently. The Herculiner was showing it's age after 4 years of hard (ab)use.
Nice job.
few would appreciate... outside of members here
I was finishing up pulling stuff out... brainstorming inside my head what to do next... I bragged to the sprinkler guy (who was doing routine maintenance on our sprinkler system to the power source inside our garage) that I was getting ready to simple green the whole inside of the rig!!! He didn't seem to share my enthusiasm. Not much later :princess: got home and she is a big advocate of cleanliness, but I knew she wouldn't appreciate simple greening the inside of my prize as much as me... I thought about calling my fire fighter buddy over who built up his 90' toy pickup, but knew he didn't have that same appreciation and pride for simple greening the inside of a Landcruiser. So, finally I decided I should just take some pics and if anyone was going to be able to appreciate what I could, they'd probably be found on here. Hence, the title for the thread.
A couple questions for you knowledgeable owners...
I really like the green floor with the black linex (or whatever its accurately named), the ease of not having carpet to damage, and the idea that I might just be that much closer to being ready to run this beaut through deep anything. Is there much need or use for carpet inside the rig??
Also, the PS seat was working fine before removing everything. Since putting it back in, the left side of the seat won't move when the forward and backward adjustment is made. The infamous little white cap is there and tightened. Any ideas as to why the left side is not budging at all? Everything seems to be working fine in regards to any other types of adjustmets (up down etc.) Is it possible that I messed up that side of the PS seat positioning with simple green in one of the connectors? or is this a common trait of gear malfunctioning???
Thanks (for appreciating a pristine beauty that's just been simple green'd!)
I would guess that carpet adds some sound deadening.... have you driven it with the carpet out to see (or hear)?
Also, I power-washed my interior carpet (of one of my older beater/flipper cars) with hot water (after using 8 cans of spot shot to really soak the bad areas). Looked (and smelled) brand new. It did take a few days of moving it around in the sun and propped up on buckets to finally dry.
I'm currently driving with half my carpet pulled (rear carpet). Huge difference in noise, way louder.
