Build Fergytoy's 1965 FJ45
Well, it was time I got back onto the wiper arm/blade issue. Been a hassle trying to find a blade adapter that would easily mount to the old style wiper arms from pre-1968. My FJ45 is a 1965. I have quite an assortment of adapters I have collected over the years but none worked for this type of arm. I contacted all the big Landcruiser parts suppliers and no one had any answers, Spector had a good listing of adapters shown on their website but they were no longer available. I checked out Amazon and found the below adapter that works but is not perfect. It does not just snap onto the wiper arm. But with some easy modifications..................it works well.
The factory hole at the very end of the arm is threaded. A 3mm X .50 screw goes right in. Then I drilled a hole in the arm to align with the other hole on the Amazon adapter and then ran a tap thru it.
I will be driving my 45 over from GJ on Saturday to attend the Rising Sun Swap Meet in Lakewood. Do you plan on being there?
Yup, I’ll be there love to check em out. Won’t have the truck, wanted too, rear axles are out and hasn’t run for a few years (but does!) I had a too much to do. I’ll look for you.
Bob
Decided to change the carburetor cable out for linkage like it had from the factory. Been sourcing some of the carb brackets and linkage from various sources. Also found good fitting rubber grommets from True Value for the firewall bracket since the are no longer available from Toyota.
