Build Fergytoy's 1965 FJ45
Old pins came out easy enough.
The small skinny piece of metal at the bottom of the photo is what I call the valance. It has small bolts on the back side that mount thru the windshield just above the vent flap. The small holes along the edge of the new rubber gasket mount thru the small valance bolts and are held in place by small nuts on this inside of the windshield frame. The actual vent flap sandwiches the rest of the rubber gasket between its interior steel plate and outer steel flap/vent. The bigger holes in the rubber gasket is where it bolts together in that sandwich. The screens are in good shape with just a little tear here and there.
Gonna replace all the hardware for this part of the project. Lots of small bolts and screws that were challenging to remove. Discovered that the defroster vents actually screwed directly to the directional metal pieces at the bottom edge of the windshield. Was able to remove them by dropping them straight out of the bottom of the dash.
