ARCHIVE Feeler-Group Buy 80-Series 10" Sub Mount
Just put in an order…
How much room is there behind the bracket for the sub? I want to make sure the subwoofer that I get will fit...
I will get you measurements Sunday.
...via IH8MUD app
Dead center is just over 4". The top is 3"0 and bottom is 4.5"
Measurement taken inside of circle cutout. Top, center and bottom.
If you find yourself wanting a specific brand and need more depth, you can buy spacing rings to give you more depth.
Shane.
...via IH8MUD app
The hanress circled in yellow has a retaining clip that uses the lower right mounting hole I have used. So I am putting a hole where the blue circle is and one on that bottom side. This will allow you to run the harness on the top as per factory or under the mount.
Everybody get thiers ordered? Coupon code "80sub" for the MUD group buy discount @ www.MetricTLc.com
Shane, any update for the other larger panel? I'm holding off getting this piece before I know the other is coming. Reason is I already have the whole hog piece and I'd assume stick with it if you wind up not making the second part.
The other is coming as ill need it for options that we're installing. Had to take a break as we've got many irons in the fire.
...via IH8MUD app
...in for sub mount + accessory panel combo. Is the PS cargo panel identical on the Lexus LX450 and, if not, can I still make it work?
Shane, do you know how much if the sub mount would be blocked be standard ARB drawers? From the pics it looks line maybe a couple inches, but would be good to know as I eventually plan to get drawers.
I ordered mine, but have not received it yet. Do I have to wait for it to be made or are there a bunch in stock?
When I went to order one, I got this: "Unable to find Specified Product in Catalog."
It does at the final step IIRC
Looking forward to this ! Already got my sub ordered as well and the wires run from the amp under the seat !
Shane.
...via IH8MUD app
What is the price and thickness of the spacing rings...I didn't see them on your site?
I just ordered my bracket, which sub did you go with? I have a 10" Alpine type R shallow mount built into the base of the front center seat of by ram 2500, which works well in the confined space. Interested to see which subs others are choosing for this application.
When I try an order it on your site it says unable to find product. I want one and the 25% off is great!
...via IH8MUD app
...via IH8MUD app
Try the link on page 4...I just ordered one with the 25% off about a hour ago and it worked (This mod seems freakin perfect...I'm not excited at all!) :clap:
I found a 3/4" spacing ring on ebay for $13. This should clear the Kicker CompS 2ohm speaker I ordered. Can't wait to install this!
