fan intake rubber
Helena MT
Is there a need for these reproduced? I've got a good 1 that can be used as a mold/template. I removed it today, no new pics, just this old one from when I brought the rig home. It's still soft and pliable.
What I'm offering is this one to be used to replicate "new" ones if someone has the connections and there is a need.
probably...i know my two are "holding on", but that's about it. only thing is it would have to be relatively low priced since once could use an innertube or something, so it may not be "worth" it.
I did use an innertube on mine. Sorry I don't have the size, but went to a larger tire dealer and sorted through the available tubes. Believe the one that was the closest fit was for a forklift tire. Not a perfect solution but nice to not be sucking engine fumes into the heater blower.
this is the first piggie that I've come across with one
I thought they might be the same thru the years as the blower motor was always on the firewall, but not 100% sure.
what year 40"s? in what location on a 40? it is different than the rubber between the duct and heater box inside.
I thought it was the same as the heater box to duct piece on 68 to 73's? Got that off SOR. It seemed the same size. I am not 100% positive of this though.
Been there, tried that. It's too short by just enough to not work with the slight angle and the factory clamps.
