fan clutch
lebanon,pa
Website
www.facebook.com
how *free* should the clutch be at normal op temp?
noticed tonight, that after running at temp for a while, then shutting down the engine, the fan kept spinning for longer than i thought it should.
so i spun it by hand, a new, well lubed bearing would not spin as free as this fan did.
so when an engine is shutdown the temp climbs for a bit after that. i let it set for a few minutes and watched the gauge. when it spiked(just above the second line \....l.H...l..../) tryed spinning the fan agian, with no change free as a bird.
guess i could use a *new* fan clutch?
Can you hear the fan engage when driving in traffic in hot conditions?
I can easily hear the fan engage when driving in city traffic...
There should definatly be more friction than a bearing should have...
Does the fan blow hard for a few seconds at startup and then stop?
I would just replace it...
