Does anyone else have this issue? I have the factory remotes on my '96 (RS3200 I think) and when I set/unset the locks:
#1) I have to be within 5 feet of the truck to activate - even after replacing the battery in the remote. Practically on top of the truck! This is with both remotes. Other Toyotas usually from much further.
#2) When it does activate, more than 50% of the time, it will not audible. Only the parking lights will flash and will lock like usual. Curios...I know on my last 4 Toyotas, it will beep everytime.
Nothing worth worrying about really but still a pain when parking and trying to set system, I cannot start walking away and do the casual behind-the-back "beep-beep"
. Im usually catching up with the family because I have to walk back to the truck and set it.
A side note: I'm going up north this weekend toget out of the Phx heat and towing a trailer. I have run warm at idle/ac on occasionally in the high heat. I have been researching threads on the popular cooling related topics. Wow - alot of info and then some! 115 degrees and supercharged gives me a little challenge to start with. My cooling system is in great shape but Ive gleaned enough info to get an OEM blue hub fan clutch and install before the trip. Appears a 5 to 10 degree drop in temps based off of feedback via other Mud owners performing this. My OE clutch is undoubtedly tired and this difference should get me to where I need to be.
. Im usually catching up with the family because I have to walk back to the truck and set it. A side note: I'm going up north this weekend toget out of the Phx heat and towing a trailer. I have run warm at idle/ac on occasionally in the high heat. I have been researching threads on the popular cooling related topics. Wow - alot of info and then some! 115 degrees and supercharged gives me a little challenge to start with. My cooling system is in great shape but Ive gleaned enough info to get an OEM blue hub fan clutch and install before the trip. Appears a 5 to 10 degree drop in temps based off of feedback via other Mud owners performing this. My OE clutch is undoubtedly tired and this difference should get me to where I need to be.
