factory a/c idle up
Helena MT
1980 FJ40 factory air, does not idle up when a/c is on. as soon as I manually idle up with my foot I get plenty of cold air. The vacumn lines on the carb appear to be there and connected. Getting ready to go to BHCC and it's warm.
Is it factory A/C??? Not to offend you, but I have seen ones that people say they are OEM.
on the side of the controller under the dash at your knee there is a rubber plug. Pull it out and follow directions on the side.
AND, if you follow the vacuum port off the manifold (the ribbed one) it will go to a control valve, it it hooked up and test the valve. Then it goes to the vacuum pod on the carb. put vacuum to it, does it function?
