F155 Redline?
Honolulu, HI
So whats the hypothetical redline before VeryBadThings(R) start to happen?
Anything I should know before romping on the skinny pedal?
And, is it possble to set some kind of throttle limiter to avoid going over the redline? Maybe a thingy on the throttle cable or something...
How many licks does it take to get to the middle of a Tootsie Pop?
;p
Engines are horsepower rated at something like 3800rpm, but I certainly wouldn't want to run one there very long.:eek:
If the engine has not been rebuilt, then it is far from balanced, and probably has a pretty 'healthy' [and I use that term loosely] vibration by 3000 rpm. Vibration is the enemy.
If the engine has been rebuilt and balanced, 3000 plus is not bad. I've strayed above 4500rpm for brief bursts in the sand dunes, but that's about it. It might go more, but I have NO intention of finding out.
Once you get to a certain point in your life [some call it middle age] you become more interested in how long things will last, rather than how fast they will go.
Hth
Mark A.
Yeah, if thats the case, I think I've hit middle age. Just wondering in case a situation ever calls for a quck burst of I-6 maddness. How is an engine "balanced"?
Anybody know how fast a stock 40 will do 1/4 mile? :)
This brings back memories.,,,,,,
1987 at the Woodburn Drag Strip in Woodburn , Oregon I took second place in the high school drags.
Running a stock 74 FJ40 with the hard top removed and the windshield folded down I ran 18.08's at 77 mph all day.
I still have the "Drag Script" paper with my name and rank. And in the head lines was stated the ONLY 4x4 out that day.
It was cool and the grand stands were roaring when I was 18.08's . I was let go with 3 to 5 second head starts.
Cool High school mod was that I made a tilt front end in shop class. I trimmed the inner fenders and knocked out the pin in the hood hinge and replaced them with push locks. Bolted the hood to the fenders and pop a head light out every time I tilted it forward due to the tow hook smacking the head light.
what can be the cause these vibrations? Mine (2F 1977) won't go up to 3000 rpm.....
I think 2400 rpm is where it gets uncomfortable.... but my engine doesn't burn oil or anything...
Vibrations are due to the crankshaft being unbalanced. If you've ever seen one of those clear vibrators :grinpimp: then you'll see that theres a motor inside, with a metal chunk on the output shaft. That chunk of metal is not symetrical, its usually half a circle. When it swings around, it makes it vibrate. Your motor is like a vibrator, the crankshaft is the motor output. If your engine is unbalanced, then its not equally weighted all around. It tries to move the block with every revolution.
Oh gawd, its true, every thread either turns to drugs or sex... lol.
