Krondor
So I finally got around to tuning my engine. An original F135. I hooked a vacuum gauge up to the intake manifold and got the engine idling around 500 RPM. The engine vacuum reads around 18 inches of mercury at idle. The timing light has the timing it set at exactly at the TDC line.
SO I figured I would take the old girl out for a test drive.
I noticed a little sputtering when I first drove out of the drive way. Nothing too serious. Got her up to around 40mph then stopped at a stop sign. Oil pressure was fine. Temperature was right in the middle. Then the old girl died. I tried starting it again and it would idle fine. As soon as I would give it any gas, The carb would back fire and it would sputter out. I managed to reverse it off the road.
I had a difficult time opening the hood because it was HOT! Like burn your fingers hot. I let it cool for a bit and the air cleaner was just as hot. This is when I noticed that the gas in the carb window was boiling…. ****.
So I sat on the side of the road until one of my friends could pull the 40 back to my garage…
Valves have been correctly adjusted.
Idles just fine.
New thermostat
New water pump
New coolant, I have burped the radiator and not have had any issues when idling for a long time.
New oil filter and oil.
All fluids correctly filled
So I leave it up to you. What have I done wrong? What could have caused this problem and how can I fix it?
Idles just fine.
New thermostat
New water pump
