F power steer pump mount
Holladay,Utah
I was looking for some pics of your power steering pump mounts on an F motor.I would like to keep my stock air cleaner,so I need a lower mount(where the alt. is now).I think Marks Off Road sells one for a sag pump.I have a 60 pump,but will use whatever works.I have a 71 fj55.Thanks for any ideas.
I have a F1.5 in my 74 and I put a 60 pump under the aircleaner using the alt. mount and used a 78 alt mount to move it to the passenger side.
pump mount
I like that toy pump location.The bracket mounted to the front of the pump must be custom or where could i find one.How does it mount on the bottom?i like the sag setup as well.Where did you run your PS lines to the box.Thanks keep em coming
I used a stock 3FE power steering pump bracket that sets the pump on the upper passenger side and then modified the 3FE alternator bracket to position the alternator below the air cleaner on the drivers side.
there are some pictures of it floating around Mud somewhere, I could dig them up if it sounds like something you'd be interested in?
Call marksoffroad.net in Burbank. He has a mount for the drivers side and will fit underneath the stock air cleaner for the F.
Hmmm...more pics and info please :beer:
Sean...I like what you did also. Not for my current toy, but something to keep in mind for a future rig :)
toyo
I like this setup toyofj40.Most want a sag pump,but Id rather stick with toyota.I will try to fab the brackets i guess.Is this what you did?Thanks for the pics.
I used the Mark's Offroad bracket. Works great.
I understand the desire to use a Toyota pump, but the Sag really is better and cheaper and much easier to find pretty much anywhere. (cept maybe Japan. ;) )
Either way, good luck!
mount
Marks bracket is for the sag pump only,correct.Sounds like I am making things harder than they have to be.Just order the bracket from Mark get a sag pump and be done with it.I just like the T on the pump cap.Here in Salt Lake we are very lucky to have Cruiser parts that never seem to run dry,so a toyota pump is an easy find.Thanks for all the advise and pics
I used bracket from orange45. I was able to use my stock air cleaner, all I had to do was rotate it a bit and make an extension mounting bracket. I will try to post a few pictures tomorrow if I can get to it.
Thank you for your interest in my product but...you did not mention whether or not your '71FJ55 has a single, double or triple groove harmonic balancer, and that should be a VERY RELEVANT part of your decision-making process.
I am firmly of the opinion that the p/s pump should be on its own dedicated belt EXCLUSIVELY with the harmonic balancer, with 180 degrees of belt wrap on the pulley. You would be hard pressed to get much more than 90 degrees worth of belt wrap in any single groove balancer installation, and when your steering squeals, you will know why.
Further, my bracket was specifically designed for use with a dual groove harmonic balancer. Therefore, if you neither have a dual groove balancer, or the desire to install one, my bracket is not for you.
Lastly, I developed a special version of my bracket for use on the FJ55, because the steering/clearance requirements on it are different than the 40 series. ;)
Best
Mark A.
Marks off road
I have been looking for answers to that very question Mark.I have a double pulley setup off of a 74 F.The pulley has a wide groove and a smaller groove that make up the pulley.I only have single in the 55 right now.I could get my hands on a 60 double,but I just put a new water pump in mine,and dont want to change it out for a 60 water pump.I heard this is what I would have to do.What do you recommend I do?Here is a pic of the double pulley I have out of a 74 F.Will this work with your setup?Tell me what I need and I will buy it from you.Thanks
You CAN do the Saginaw conversion with the 74 pulleys. I have a narrow groove alternator pulley that will finish out your installation.;)
818-953-9230
I'd love to see a pic of how it all bolts up. As I'm hoping to install mine tomorrow. Anyone have pics of Marks set up?
