F Head - 60030 vs 60032 casting differences
Maine and New Hampshire
Found out I had a cracked and JB weld repaired head when I went to pull it for a head gasket. Bolted the motor back together to keep the truck a driver while I hunt up a replacement. My head is from a 2/72 F, with casting number 60032. I found a 60030 fairly close to me, but despite a bunch of searching, can't find a good answer on whether these are a direct swap. Thanks in advance for any insight.
Here are pics of the 60030 head for reference.
I bet @FJ40Jim and/or @65swb45 would know.
Thanks Jon. It is as I thought I remembered: 60030 is the 1968 with the air injection ports. Would only have two bosses where the front engine hook goes, instead of 3. An no forward hole for the exhaust manifold. But I think the valve chambers are identical. Hth.
Yep, you nailed it - does not have the forward exhaust manifold bolt hole and front engine hook hole differences. Based on pics I have seen (very few) of the 60032 I also thought the combustion chambers appeared the same.
Your recollection is elephant like!!
Gentlemen, I genuinely appreciate the help. This forum and the Grey Beard old pros who help so generously are a treasure. @matzell found me a nice 60032 up near him, so about an hour drive away and I may just have him drop the head on and replace my 3 speed while he's at it. I'll post some pics of the 60032 later in case someone else runs into this in the future. :cheers:
Pics of 60032 casting to compare with 63000 above
