F engine woes
Homewood(B'ham), AL
I recently bought a 1971 fj-40 with an F engine, After replacing the battery I tried to start it up and it cranks, and cranks, and cranks but it doesnt start. The rotor, cap, condensor, plugs, points, coil and wires were recently replaced by the PO. Does anyone have any suggestions?
I have a question. Coming off of the carb is a wire that kindof looks like it would be used to ground it out. Does anyone know what it is? And there is a broken hose that looks like went from the air filter top to a pressure system. Does anyone know if thats what it is?
Thanks
You're getting warmer.;) That wire controls fuel flow thru the idle circuit of the carb; without power, no fuel at idle!
Hook it up to the positive terminal of the coil so that it engages with the key.
If you spend more time hunting around, you MAY find a terminal lead coming out of the firewall just to the left [driver's side] of the valve cover that provides the power source for this solenoid. It may or may not still be working.
Best
Mark A.
No, that's not the point. The only electrical connection to the carburetor controls the fuel cut solenoid. If your solenoid is not opening (getting electrical power), fuel flow is greatly reduced or cut altogether. You need to begin by looking for spark. Ground a plug wire to the block while having someone crank the starter. If you have spark, go looking for fuel. Look into the carb and see if you're getting a spray of gasoline when the accelerator is pumped. All this is pretty basic...are the plugs clean? If not, replace. Fuel clean? Have a horrible smell to it? How long has it been sitting? You may need to put new gas in it. Will it start and run briefly on starting fluid....I could go on and on...
The hose that goes from the carb hood, (the air filter top) to the top of the engine is broken, where can I find a cheap one or should I look at autozone for a similar hose? Also will gas hose work for my torn vaccum line(the one from the air filter top)?
Okay so I checked it for spark, there is no spark. I know that the connection to the coil is good because the carb solinod is getting power. PLEASE anyone list any reason why there would be no spark.
Start from the plug and work backwards with a tester, (plug to dist, dist to battery, dist to coil, and so on) until you get a positive on the tester. You need to trace the system to find what is holding it up.
Is the idle solenoid powered directly from the + terminal on the coil, or on the 'in' side of the ballast resistor? Could be a ballast problem.
Also, don't overlook the simple things, like a poor lo-volt wire from the points to the coil -. That one once got me on an engine job a long time ago.:doh:
Best
Mark A.
you do need that to run...thats a big thing to forget to put in...now isn't it!
PO's make alot of mistakes :)
Whats interesting is that the truck came with the tune up part boxes and the old condensor was in a new condensor box. What he did with it I dont know. I know that the condensor controlls the excess voltage, but with out it wouldnt the spark be stronger?
At first the idle solenoid wasnt hooked up to anything, but after some improved wiring I got it to hook up to the + terminal on the coil and it works.
Well today I took the coil off of my 62 to figure out if it was the coil. After hooking it up the same thing happened. I decided to look at the points. I then started testing for sparks to make sure that the distributer was grounded. It wasnt. Apparently the screw in the side of the distributur had became so rusted that sparks wernt going to the points. Anyway thats the story.
I think I mentioned the ground.:rolleyes:
Glad you found it.
