F engine woes
Well I think that the distributor is getting spark. I was holding the spark plug wire to the block and I got hit with 12v of electricity. However when trying to start it with starting fluid, it doesnt do anything. anyone have any suggestions?
You got hit with a bit more than +12 Volts if you had ahold of the spark plug while cranking! The coil secondary puts out between 20,000 and 40,000 volts...
You need to verify several things. Is the spark from the spark plug a nice bright blue color with an audible snap? If it's not then you need to trouble shoot some more.
Do this make SURE the distributor is grounded well. Make SURE the battery is fully charged (reads above 12.5 volts with volt meter) Then jumper +12 Volts to the + side of the coil straight from the battery. NOW check for a nice bright blue spark at the plug while cranking. If not there then make sure the point gap is set correctly and the points are indeed opening and closing. Once you get a good spark THEN start with the starting fluid...
If you go from the battery straight to the coil wouldnt it bypass the key?
Yes it will, which is the point. :-)
The jumper bypasses a lot of places where you can lose the 12Volts and if it works with the jumper but not without it then you know to start looking at the key switch and the connections bewteen it and the battery or distributor.
I know that the points are sparking but I believe what my problem is is that the spark is not making it to the rotor. Does that mean that I have to rotate the distributor or what?
