F engine trouble
New York
I need some help, please. I have a f engine that was running like a clock. I swapped out the original dizzy for a Trollhole unit. I also changed the coil to a pertronix. Prior to these changes the engine would crank right up, and run smooth. Now I have to crank it for about 30 seconds before it starts. I played with the timing a bit and left it between the TDC and the 7 degree BB. Advanced, retarded and I still can’t seem to get it to start without cranking forever! Any thoughts would be appreciated. BTW, it sounds way different now with these changes, has a more deep throaty sound to it.
Any chance the warped exhaust header flange is the source of the ‘throaty’ sound?
No, neither of those should be a problem. Both of those issues were addressed prior to me restarting the engine.
An "after pic may help". Is that a 74 40?
Did you only buy a Flamethrower coil? Or did you also buy Pertronix stuff that installs inside the distributor?
Make sure the big fat coil wire is fully seated and making good solid contact with the new flamethrower coil. You may need to roll the rubber coil wire boot back to see if the end is completely in the coil "nipple":meh::hillbilly:
It seems like you are saying the old spark making stuff had your engine running good. If so, first try your old coil. If no change in engine performance is seen, then drop in the old dissy. If engine still sounds like poo poo, report back to mud. If the old Japanese dissy reunification project smooths out your engine and once again brings a smile to your face, make a vow to avoid Chinese parts;)
I had the carb and distributor. I ended up with a large cap 2F dis and stock carb, my 40 runs like a top after months of headaches.
I tried everything and couldn’t get the carb to work right and also was having issue with the starting, backfiring , hesitating... yada yada. My fix was going back to stock and haven’t had an issue.
I pretty much did this years ago. Pertronix is electronic and throw out a points , factory system. My timing for best performance was way past 7 degrees . My guess is 13 plus. What you are doing is making an old engine better in the complete system and common sense will apply. ( Hint, best way to time is a vacuum gauge. )
I’m determined to get this running right. My objective is to have a smooth running, reliable, low maintenance engine. I believe I’m on the right path and just have some tweaking to do. I’ll try swapping in the old coil and making sure all of the wires are seated properly. I do notice that the wire from the coil to the dizzy is kinda short and is in a sharp bend, maybe this is an issue?? I still get a good spark though.
A lot of wires coming off that coil. Why?
It’s more important (essential) to have the vacuum source plugged for the dizzy if not connected.
There are four wires connected to the coil: two to the dizzy, one’s for power and don’t know what the last one for. I tried disconnecting it and the engine would not start. I’m connecting the vacuum line today.
Okay. So it turns out that the muffler was destroyed during a backfire. I was playing with the timing after swapping the dizzy and coil and remember a pretty loud backfire. I checked the muffler and it exploded, causing the crappy sounding exhaust. I replaced the entire exhaust, and now I’m back to smooth sounding engine. Thanks for all of the help here! I still have to crank it for about 30 seconds to start though. I’ll play with the timing. 1969fj mentioned timing with a vacuum gauge. What would I look for as far as vacuum numbers??
IIRC about 20 in Hg near sea level. Here @ 7,240 feet 15.2 in HG is good.
