F Engine Sputtering
Biscuit
Mars Rover Driver Emeritus
Boulder, CO
Ok my 74 FJ40 (with an older engine block, somewhere between 1/70 and 8/70) is sputtering under light loads when driving and under all loads when under higher resistance (read: uphill). It sputters but does not stall (thank God).
Now I have a feeling that this is all an issue with the mixture since I just had it brought from Denver to L.A. and this was the first drive here in Cali. I was running fine in Colorado.
I have a Weber carb (automatic choke), on a freshly rebuilt (like 30miles total) F engine.
Just thought I would see what everyone's take is on it so I can get it running properly.
Sounds like a lean misfire to me... but someone here must know more than that...
Biscuit,
You're not that guy that had his engine blow up two or three times right after getting it from the machine shop, are you?:eek:
Seems like I remember a SoCal-CO engine misadventure thread over on Pirate a while back.
Anyhow, If you've got a freshly rebuilt engine and quickly develop idle, sputtering or backfiring problems, there's a good chance that the seats in your cylinder head are still settling in and you will need to keep on top of your valve adjustments for a while.
That's where I'd start.;)
Best
Mark A.
65swb45 said:
Biscuit,
I am that guy unfortunately.
I'm still going to fiddle with the idle speed and mixture (the shop set the idle a tad high for my liking) today. Also I'm going to make some laps around the neighborhood and see if it may just be the remnants of gas from when it went in the shop.
And thanks for the heads up on the valve adjustment, (plus I think I'm going to get a new valve cover anyways mine is kinda deformed on the pasenger side and it oozes oil (which is annoying).
1.Try and use a vacuum guage when you make your adjustments.
2. I MIGHT know where you can buy a 'better' valve cover.;)
I think I've isolated the problem down to having too large of main jets in my carb. (Or at least I think)
I think that I need smaller main jets, since the sputtering (which is acuatlly backfiring occuring at the Y connector (2 into 1) from the headders) occurs only when I apply more throttle. It also gets worse when I do apply more throttle.
