F Engine Block Trivia
I shot my paint today.New Ford Grey on the block,Some color like Cast iron(all Duplicolor)for the side cover/water pump/timing cover and took one of those 2f aluminum valve covers and shot it in the cast iron.Got my order ready for Spectre Rebuild Gas and seal set.The freeze plugs for the block(I'll do the head later on) Cleaned my starter to the point that it just shines.Cleaned the Alt the same but shot a black stripe around it.This is a PITA but it sure is looking good.I'm doing an F from my June 74 and dropping in my Oct 74.Tomorrow I get to wire wheel my surfaces for gasket seating.(little over spray)Shot the block first then taped for shooting the head.(Makes taping MUCH easier)Glad to hear that's just casting in the water channel.It looked like a crack and I was like "oh,Damn" He's gonna be hatin life.I'll see if I can snap some flics.It's an unusual color combo and it's kinda cool to see someone else doing it at the same time.Later :flipoff2:
Not replacing the freeze plugs, they don't leak. I know they are dented a bit but paint hides all kinds of things! :D
The core plugs are supposed to be dented. They are Welch plugs, which are installed into the stepped hole in the block and then whacked in the center to spread the plug a few thousandths, locking it into the hole.
I thought my brother had replaced them and did a pisspoor job of putting them in!
Thanks Jim, yet another piece of Cruiser trivia!
One of the few items I salvaged from my shop in Seattle for the trip to Ecuador was a new Vermont American metric tap and die set. It was certainly plenty complete for the last motorcycle project but on the FJ40 it is a bit lacking with regards to the 11 & 12mm thread variations. But chasing threads is not anal, not a waste of time and will reward the effort down the line while you continue with the project. But the oil fill tube isn't old style, mine is old style. It has a road draft tube sticking out of it:) and it is a 1970 and someone else said those went away in 1964. Mine of course is non-USA.
Nasty looking, isn't it:)
So how much do you know about Aisan carburetors? I have one on "watch list" on ebay but the seller isn't sure whether it is FJ40 or not. The number on it I was able to confirm via directions found on Mud to be a 1962,1972 or 1982 built September 18. But there are no other numbers. I am in Ecuador and so if I were to "win" this carb I would send it to someone to have rebuilt prior to bringing it down in October, if possible. A new Aisan, for a Jeep, I saw today at my mechanics shop is $800!
Sorry I couldn't get back to you; I'm very weary of dealing with PMs in general. I did take a look at the carb. The throttle linkage does not look right for a 72, but I'm sure I could make it work once we 'talked' on the phone about what's on your rig.
As a general rule I use the internet to promote my business, and the telephone to conduct it. Thanks for your interest in my services.:)
Great, I will watch the item and we'll see what shakes out. I contacted a couple of other places which "looked" like they had carbs on the shelf. Not so, one required my core and the other only had a Weber to offer.
1bbl carburetor
So this is the carb on my rig. The date code indicates February 1971. The serial number on the chassis indicates May 1970 and the engine serial number would be September 1970. So it is probably original. The last picture shows the underside of the air cleaner and that appears to be correct for a 1bbl as well. Not sure what I would have to do or how hard it would be to find an air cleaner top for the 2bbl. I'm thinking that with the header the 2bbl carburetor would offer more power throughout the range. I do recall that in 1977 I was driving a new Ford F-100 with 300 cu in six and 1bbl carburetor and when going up the mountain out of Denver heading West (I-70 didn't go very far back then, maybe just to Aspen) I was on the floor but holding 70mph and Power Wagon's were coming up alongside of me and their speed would fall off and you could hear the rig just sucking for air. Now I'm at 8,000 feet and I want to use the Cruiser to go up into the mountains and jungles, etc. That is if I ever get it to the point where I wouldn't be afraid of breakdown leaving the driveway.
Coolerman: I have found several descriptions of the thread size for bolts/studs at the exhaust/intake manifolds. I see you went with all studs, can you please confirm the thread size/pitch and where you went for the studs? I see SOR offers a six stud kit for $29. ARP offers a ten piece stud set in 12 X 1.25 X 70 for, gulp, $100. Dorman does not offer studs in this size and everyone offers 12 X 1.75 studs.
