F Engine Block Trivia
Paint Lick, KY
Website
www.globalsoftware-inc.com
Last night while reinstalling my oil pan and other things I got to counting all the threaded holes in the block that I had re-tapped after painting it. I spent a LOT of time with the taps.
Anyone want to guess how many threaded holes are in an F block that are reachable when on an engine stand? It was way more than I thought....
I'll have pics after a few guesses...
Long block, 155 too high
Here is the engine Driver side... :D
Also something I don't know, what are the circled tapped holes for?
Bottom hole is 10mm x 1.25, left middle is 6mm x 1.0 and center middle is 8mm x 1.25...
89 sounds like a good #
DING! DING! DING! We have a winner!
Yes there are 89 holes to be tapped if you are removing all the covers and such.
13 side cover bolts
6 spark plugs
6 motor mount bolts
2 dizzy hold downs
2 fuel pump bolts
2 coil bracket bolts
12 timing cover bolts
4 water pump bolts
2 thermo housing bolts
8 Intake/Exhaust bolts
2 Oil Regulator bolts
1 Oil Hose
1 Oil Pressure Sending Unit
1 Block Drain
22 Oil Pan bolts
3 alternator/smog pump bolts
2 unknown on drivers side (see above post)
Springs and cams for carb linkage.
Dunno what the bottom one is for.
Huh? Dave put down the :beer: it's not 5:00 yet! :D
I though maybe something to do with the heat riser? I have headers so....
Well knowing Dave would not intentionally ;) steer me wrong I searched all my pics looking for anything to do with carbs that might bolt up there but for the life of me cannot find what he is referring to. Was this a pre 68 thing? Come on Dave, give me a break...
Yes, pre 68 throwback. G and K in the picture. Maybe if I remember I'll get mine out and stick them in one of my later F blocks and take a picture for you. No, wait, maybe not K because it is already rusted solidly into my 64....:D
Hmm, well I guess I'll have to bolt my flux capacitor there :grinpimp:
Thanks Dave, I would like to see a pic of that setup if you get one or if anyone else has a pic?
I'm now doing my F in the same color and my bolt ons will be a darker grey with black oilpan and head.I spent all day hunched over a media blaster shooting Black Beauty.Congratulations on your work.Are you replacing those freeze plugs?Also what's that in the water pump oriffice?I'm not picking it apart.I'm learning as I go with mine and I have a lot of questions lately.Usually they start with..."What the hell have I got myself in to?" :beer:
OK, I've associated the relevant bits onto 'Ole Leaky (I think a 1969 block) to give you an idea of how it fits together. The two return springs would attach to the pin in the hole toward the engine front, and the rod attaches to the throttle lever on the SD40 carb. Don't look too closely at the pedal arrangement, which contains some PO mods. I have another incomplete/worn set and plan to cobble it altogether into a working setup, when other, more pressing, projects are complete. :rolleyes: :D
Thanks for the clarifying pics Dave, that clears up the mystery! I saved those off for future questions! ;)
Are you going to use the old style oil filler pipe?
Are you talking about the one with the built-in PCV holder? That's what I have on my FJ45's F135 engine.
I'm now doing my F in the same color and my bolt ons will be a darker gray with black oil pan and head.I spent all day hunched over a media blaster shooting Black Beauty.Congratulations on your work.Are you replacing those freeze plugs?Also what's that in the water pump orifice?I'm not picking it apart.I'm learning as I go with mine and I have a lot of questions lately.Usually they start with..."What the hell have I got myself in to?" :beer:
Not replacing the freeze plugs, they don't leak. I know they are dented a bit but paint hides all kinds of things! :D
That is casting debris in the water pump opening. It's very firmly attached. I tried tapping it loose but it won't budge. I did get a coolant filter which I will plumb in when I get that far. IF you want to see ALL the pics of my resto-revival see the web site in my sig.
I have spent many many hours in front of the sand blaster. 4 hours last night doing up a bunch of bolts and brackets. I'm doing silver/black/red anodized theme...:grinpimp:
Not sure if you were asking me or not but yes I plan on using the old style tube. I will be running the 2F aluminum valve cover though so I will have two oil fill caps. Can't wait to take it to an oil change place just to watch themn scratch their heads wondering which one to use! :D
Hope I didn't spoil your trivia too early, it's just that I may have been as curious with "chasing holes" as you were/are, and the # seemed to stick with me.
You kidding? :lol: I KNEW someone would know the answer! The amount of work we put in to these trucks is insane. The more I do the more anal I get about it...
Just so you know, this is NOT a restoration and the truck WILL be driven off road. I just get carried away sometimes when cleaning things up...:beer:
