I made a rough CAD drawing based on a cardboard template I traced out. But I need to 3D print this to test fit with one of the panels with the suction cups attached to check the dimensions. I finally got a small 3D printer (Bambu Lab A1 Mini) so it will be put to good use on this project.
My initial concept is that 2 of these would align with the lower set of roof rack bolts on the Dissent Rack. (The higher bolts I'm using for the Dissent Awning Mount).
As the suction cups hold the Molle Panels away from the rear window a bit, I'm not sure if I need an additional bend / distance for adequate clearance.
