- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,199
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
Decision time
OK, we have a few choices for tank. None of them are a direct swap, unfortunately.
First, there is the P30 StepVan Tank.
Pro: Cheap- $189 delivered.
40 gallon capacity.
One inch smaller than stock tank in L & W dimensions, and only 13-1/8" deep.
Con: It fills at the front corner, not the rear corner, like a FJ60.
Second, is the Ford PU Tank
Pro: Cheap- $150 plus postage.
38 gallon capacity
2" narrower than stock tank, allowing wiggle room for exhaust or fuel fill routing
Fills on center of side, closer to rear corner.
Con:
fuel pickup is at rear, requiring extended fuel lines and fuel gage wiring
13-3/4" deep, 5/8 deeper than the P30 tank.
The Burb tank is the same as the P30 tank, but the filler is up on top, which is an uphill run from the stock fill neck, plus it pushes the tank down away from the floor of the FJ60.
I am leaning toward using the Ford tank, and having the muffler shop s-bend a piece of 1-5/8 pipe to go from the Fj60 fill neck to the center side of the Ford tank.
Using the P30 tank would require welding shut the stock fill holes, and then weld in a new piece of 2" pipe at the rear corner to connect to the FJ60 fill neck. I actually would prefer the welded neck approach, but I am really trying to keep this as a "no welding required" project, so anybody can bolt it together at home.
P30 or F250 tank? Discuss amongst yourselves and then decide.
40 gallon capacity.
38 gallon capacity
Con:
