That was my original plan said:Good call VI. I totally forgot the rear tapers and had no idea the corner radius was different. Keep up the great work!
That was my original plan, but upon close inspection the sides taper at the back and the radius top & bottom are not the same. So to avoid the frustration of matching up & feathering the two halves together, I am just using the bottom part below the windows and then fabricating reinforcement and attachment points to the driprail & cap.
Stock springs with extended shackles 1" over stock. Body is currently resting on the frame. I have fabbed up some 1/2" rubber body mounts out of semi mud flaps for when I get to that point. They look just like stock mounts.How much lift on those springs?
Do you have any pics of the body to frame mounts?
Its lookin great!
Pretty disapointing. I knew the back end tapered but the sides are more subtle so i didnt see it. The only way i can see to fix it is to section down the center and fill in the gap. Not quite sure how to do that and still maintain ridgidity. I've never worked with finerglass before. Last night I cut and bent and got all the side pieces down to the same hight. I was all excited this morning, busted out the jig saw and cut some fiberglass. My excitement soon faded however when I put the cap up on the trailer and realized that something was not right. The cap is too narrow by about 1-1/2". As is, the outside edge of the drip rails is about flush with the sides. Apparently the top sides on the 40's actualy taper.Pretty disapointing. I knew the back end tapered but the sides are more subtle so i didnt see it. The only way i can see to fix it is to section down the center and fill in the gap. Not quite how to do that and still maintain ridgidity. I've never worked with finerglass before.
Days like today make me question cost vs reward on this project.
Thanks. dont worry about checking. Im commited to fixing what I have.Really looking forward to see this thing finished. As far as the fiberglass the earlier ones were wider. The top that fit on the corrugated sides. They were also higher and some had the vent in the top. I'm not sure when the top started to angle in. I have read that is was in 74 but I have a 73 top and it is angled. The angle is about the height if the bottom of the window opening. I can check a 88 and 72 sides this weekend to see if they are angled. Might solve your problem with a different cap.
