Exhaust heat riser gasket replacement
Southeast of disorder
How hard is it to replace the gasket/heatriser (see #8 in the dwg. below)? I've developed a leak at that location and I've never done this job before. I'm about a 1/2 to 1 banana mechanic. Anything I should know before i tackle this? Thanks in advance.
well if its rusted together like most be prepared for some swearing and breaking of bolts, wrenches and knuckles of coarse......
Well, for me the biggest pains are getting the carb off and on (tight spot for wrenches) and then getting the new manifold gasket (#1) sealed well. It is important to use an OEM or at the very least a Felpro gasket there, and to torque it properly and to retorque several times over the next week or so to make sure you don't get a leak.
What makes you certain that the leak is the gasket between the manifolds?
I've done this and I can tell you you're opening a can of worms. First there are two gaskets that sandwich the heat riser plate. More than likely the riser plate is cracked. 2F engines are notorious for the heat riser deflector to eventually fail and lock in one position. That wound spring is what is supposed to deflect the exhaust gases from continually striking the underside of the intake manifold. When this heat riser deflector mechanism stops moving it generally will lead to cracking in the intake manifold under the carburetor (this takes years to happen). Check and see if you can easily rotate the riser plate by hand with the engine cold and if it works, carefully check at a stable engine temp at idle. The other item you need to be aware of is that since the intake is made of cast aluminum and the exhaust is made of cast iron there is the likelihood that the assembly has internal stresses that may be released in the form of warpage when you disassemble them. This is due to the fact that these two metals have different values for volumetric thermal expansion. If this occurs you may want to bite the bullet and put a set of good headers on. Back in the 70s' Toyota was very aware of this issue and I know of two machine shops in Tucson that made a good living surfacing the assembly bolted together so the dealership could fix the customers complaints. If you see a crack in the intake manifold when you remove the carburetor or separate the two manifolds – don’t panic. If there is a crack, any good machine shop can weld it. As a matter of fact, my backup intake needed to be welded on both sides. Another issue you may run into is that the two bolts that are in the front of the assembly thread into the intake and when you remove them it may strip the aluminum threads . Again, any good machine shop can fix this. You can buy inserts from McMaster-Carr and do it yourself. They are M10 x 1.25.
Well, there is only 1 "heatriser" gasket on a 71, like your figure shows. But you definitely should be looking for a cracked intake when you're in there. You may be able to see it when you take off the carb.
Sorry, I was relating to my 78 that has two. My apologies
Just didn't want him confused, looking for a second gasket! :D
I can see the gap at the right hand corner and feel the exhaust leak. I guess I can just unbolt the intake and exhaust manifolds from each other and slip the gasket in and bolt them back together? My exhaust manifold may also be cracked, but i can't tell for sure without taking it out for a closer look.
I think you'll have to take the manifolds off the head to do it properly. You have to take out the 1 through bolt and two bolts holding the manifolds together to get the old gasket out (it probably will involve some scraping). Even if you could get in there without taking the manifolds off the head, you'd probably break the seal on the manifold gaskets. I'd just bite the bullet and take 'em all off.
Damn, sounds like it's more work/money than I'm ready for right now. Will it cause any problems to just drive it as is other than just being louder? I think I'd rather work on the steering and brakes first.
If it is a minor exhaust leak you can probably run it for a while without damage. If it is a intake leak, then that is another story. Intake leaks can cause a cylinder to run lean, causing an engine to run hot and valves to burn and pistons do not care for a very lean environment either. Just make sure it is an exhaust leak. It would be good to use a length of 3/8 or 1/2 inch hose to try to issolate the sound by putting it around the area of the leak and listen for maximum volumn.
I'm pretty sure it's an exhaust leak, I can feel the warm/hot air coming out of the gap, and the engine runs cool.
You might shoot some unlit propane around the leak to see if the engine increases rpms which would indicate a vacuum leak. Hopefully, the leak would not be a crack in the intake, but if the propane is being shot from under the carb and not near a vacuum hose or fitting, then.....
Good call. A can of carburetor cleaner will also work.
