My 1997 with 216K seems to be a little soft in the suspension as regards to roll (of course, I have not driven another 80, so I have nothing to compare it with). I have replaced front and rear shocks. Is this normal, or is it time to replace springs?
Springs are likely very worn if original, though stock ride is softer/more roll than aftermarket springs. Also check the rubber bushings in the suspension arms, makes a big difference when replacing those as well if worn.
Coils springs age and sag. It was a world of difference when I changed mine out for OME stock height coils (861/862).
It's easy and cheap to do. You get about 1" of lift initially, although they'll likely settle a bit after the first month or so. If you've recently replaced the shocks, no need to change them. Also, no need for caster correction, etc. Simply R&R the coils and you'll be a happy camper.
The rear spring on my 80 wear so worn at 180k that they wouldn't support the rear without the shocks installed. As I was installing my lift I let the rear down on just the springs because I was having to repair the upper shock mount and was done for the day. The rear sank nearly enough to make the tires touch the wheel well.
I got mine from Slee, but should be commonly available.
There is no need for anything other than the coils if the shocks on the truck are fresh.
These do add a bit of load carrying capacity. If you have a lot of junk up front (see my sig line) then you may need a set of beefier shocks to dampen things. I started with the OEM Tokico shocks all around, but then swapped in a pair of OME Nitro Sport shocks to dampen out things. She rides sweet now even with the odd shock combo.
For a stock or mildly loaded truck, just swapping the coils should work.
If you're not looking for a lift, then a big X2 on the OME 861/862 springs. No more wallowing, leaning, sloppy handling pig of a truck like it was stock, does away with body roll and makes it feel like a racecar in comparison. They work well with stock shocks, and require no other mods (castor correction, extended lines, etc). I had these on my last truck and loved them.
OK, I got the OME 862 springs for the rear. Just what is involved in installing them? Is it as simple as removing shock and jacking up the body till full extension and pull it out?
those bilsteins are the same as I had, it felt like a boat, and mine were still new (4 months) I just replaced them with koni 90 series and its fantastic now
Nice looking 80! Make sure you check your sway bar links front and rear (the proper term for a sway bar is "anti-roll bar" which is what you seek) to make sure some of your body roll isn't coming from there. I did the OME stock height springs and they're nice, but body roll really is addressed by the ant-roll bars and the shocks. My experience with shocks is the better (unfortunately more $$) you buy the better it helps. Cheap is cheap in this department.
For your case yes, disconnect shocks at the bottom, disconnect sway bar (makes it easier), jack up the frame one side to get wheel off the ground, remove wheel, pull spring, replace spring, install wheel back, lower frame, go to the other side and repeat. Reconnect shock and sway bars and you're done. Keep an eye on brake line extension as you do this. Its a simple job assuming your fasteners aren't rusted... if they are then you can snap bolts/studs etc - use a good penetrating lubricant for a few days before hand if rust is a concern.
Most of all this stuff is on this forum already, learning to use search (which does work very well) will provide you lots of information. i.e. most any question has already come up and been answered in the past 15+ years of this its existence
