Sub'd
Never mind. The new fuel they sell us has some serious issues...
Lucky! We definitely don't get that in California. Hope it helps.
Just for reference, I still have excessive fuel pressure in high elevation. I have the VC120 and new gas cap. I'm not sure where to go next. Luckily I only have had this problem 2x. Problem is I am planning a solo trip to 10,000ft in Mexico in July (all back country roads and no services), and would love to have this addressed.
Maybe the fuel pressure regulator if you did all the other stuff.Just for reference, I still have excessive fuel pressure in high elevation. I have the VC120 and new gas cap. I'm not sure where to go next. Luckily I only have had this problem 2x. Problem is I am planning a solo trip to 10,000ft in Mexico in July (all back country roads and no services), and would love to have this addressed.
Anybody ever looked at the words on Mr. T's gas cap? Drove my 94 around Durango today. Last time this tank was filled was early March. It's been in my garage since. Low 90's here today. I got a little hiss of vapors, but not too bad. Sitting on the garage now I have gas fumes off the driver's side of the hood. My 94 didn't do this in TX.
That is your charcoal canister letting out excess gas.
However in my case the brand new VC120 still did not fix my problem. I am going to inspect vent lines I suppose.. .
Finally got around to chasing down the leaks in my filler neck and as I anticipated, I am now getting much more fuel pressure built up when I go to loosen the gas cap.
I am going to try to leave the cap loose for now so I don't blow the JB weld putty out and toss in a VC120 to see if that takes care of it. At least the good news is that my tank probably doesn't have a hole or a crack yet.
I plan on swapping out the tank and filler neck this fall along with a new skid plate. I hope the VC120 helps until then.
How much "wooosh" should I expect under normal conditions? My rig has had pin sized holes in the filler neck since I have owned it so I am not sure what normal is.
I get zero "wooosh"
Alright. That is what I will be shooting for. You deleted the check valve though, right?
