excessive brake drag
I feel like I am getting some excessive brake drag. On slight inclines if I drop it in neutral the truck does not role. If I get it rolling slowly in "D" then drop it in neutral I can feel it come to a stop with like there is a little drag some place. Also if I lift the rear axel and turn the wheels it feels like I have a lot of friction in the rear.
Let me give you a little back ground. Front end birfields and bearings are all new and torqued right. Front calipers are fresh rebuilt, now OEM pads and rotors. Rear end 1 year old pads and rotors and calipers rebuilt. New rear axle seals and wheel bearings re packed and re torqued. I had the wheel bearings torqued a little tight, no binding at all but a little tight. I retorqued them properly to FSM directions so now they are GTG. Also i rebuilt the brake master a few days ago with OEM part.
My first plan is raise the rear and adjust the e brake per FSM. Next I will try adjusting the arm from the booster in (shorter) just a little since I changed master cylinder parts. I just want to see if perhaps the booster arm is too long and putting a little "preload" in the brake system. I had adjusted it out in the past about 1.5 turns to get rid of excessive pre travel and it felt fine with my old master. So it might need a slight adjustment. I am hoping that these two things can straighten it out. But any other ideas?
I had my rear drivers caliper get stuck on me to where only one side of the brake pad was being used. They where so bad I had to get a new caliper,(rusted), so I went new rear calipers, rotors and pads.
Jack up truck. See what tire is dragging or all. If all then the push rod on booster is prob to far out. If just one. Inspect , fix or replace.
If both or one rear I would inspect ebrake parts internally.
My ebrake was hung up when I bought it. It did the same. All parts inside drum where jacked up. I replaced and no more drag.
I just did the rear bearing on mine and found my passenger side parking brake shoe made a nice shiny band on the inside of my rotor...the parking brake still doesn't work... I would look into that to rule out obvious signs first
Don't know on these , but on any other make including Toyotas, in the Midwest the brake cables get rusty inside and won't fully release-doesn't take long either-less than 10 years old. You either have to use it daily or never at all. You can CAREFULLY feel the brake rotors after driving a distance without much braking and they won't be very warm-EXCEPT the one that's dragging will be hot.
are you sure you put the 2 seals in the MC in the correct slots, one seal has relief ports, if you have them in the wrong order it will cause the brakes not to release properly
From what i saw the seals were all on the two pistons. Basically just drop the two pistons in. The only thing i could have done wrong was the installing of the piston stopper bolt. I cant remember if i installed the pistons first or the piston stopper bolt. Not sure if it matters or which is the right way.
Could it be the Piston Stopper Bolt that wasn't installed correctly?
How did you correct that (from your other post)?
It is possible. Tomorrow night after work i am going to try to adjust the rear e brakes and dig into this a little. I have not had time to mess with it yet.
I fixed it, not sure exactly what it was but i have a idea. I lifted the rear end and started adjusting the e brake per FSM. I was really feeling for drag and when it was caused. I ended up pulling off the calipers so i could get a better feel for the drag. with the calipers removed and the E brakes baked off everything spins well. I removed e brake cables from the arms and backed off the pre travel screw on the arm per FSM. Things turned nice but with one problem. The passenger side turned well clockwise (forward) but counterclockwise (reverse) i had drag. I pulled the rotor and found some slight discoloration on the e brake brake surface from heat. I figured maybe i had something binding a little on the brake shoes. Everything looked OK on the shoe. Maybe the shoe surface had a little high spot on it or something. I didnt have the option to replace parts right now so i was going to have to make do with adjusting it. I tried adjusting the shoes a little looser than normal to make sure they didnt drag while driving. Another thing i did was made spacer's from 3/4 PVC to go under my wheel lugs to hold the rotor true. If you have a 94 the wheel lugs wont touch the rotor without the wheel mounted. I cut some 1/2 pieces of PVC and put them under the lug nuts so the rotor was held nice and flat while adjusting the e brake. I think this is really important to getting it sitting straight. Once straight i could feel things change and the wheel then turned easily forward AND backwards. Not sure exactly what was binding on the e brake. I pulled the rotor off and everything looked GTG under it. I guess i had something was not sitting straight under the rotor. I adjusted the e brake and moved on to mounting the calipers.
I mounted the driver side and only picked up a SLIGHT amount of traditional drag. I mounted up the passenger side and felt some drag. Te piston felt tight to push back in on the caliper. With closer inspection i found a spot where the dust seal on the caliper piston was bulging and not mounted well. I was not real happy about removing the caliper but i needed to. So i pulled the caliper, pulled the piston out and cleaned it all and resembled. The dust seal is a little bent but i got it mounted in the groove and the piston back in. Ideally i would have picked up a new seal. But i just dont have time. I head out for Wyoming in a few days and just cant do it. The caliper was rebuilt with OEM parts about 9 months ago. SO other than having a little "pinched" area in the dust seal it is GTG. I got it all back together and i think it will work well. The piston moves much better with the seal seated properly. If it gives me any problems i can have Beno send me another seal.
While i was redoing the caliper i accidentally lost all my brake fluid. So i decided to address another concern. I recently rebuilt my master cylinder and had some concerns about how i had installed the piston stopper bolt. So since i had to bleed the system anyway i pulled the master out and reinstalled the piston stopper bolt per FSM. I have no idea if this even mattered. But now i can stop thinking about it.
I bled the system and the peddle still feels a little soft. But it stops like crazy, no brake drag at all and e brake is much better. I still need to adjust it inside to take of a little cable slack. But most importantly it roles easily on VERY slight inclines. Id i put it in drive and then quickly into neutral it will role forward and slow to a very gradual smooth stop. When the brakes were dragging you could feel it come to a stop with a little lurch. Not any more. Much better.
Overall i think the e brake needed fine tuning but mostly i think it was the dust seal making the caliper piston hard to move.
another little bit of info to share with other 80 owners. When removing the rear rotors watch that the e brake shoes are not binding with the rotor. The rotors will be on tight if they have not been removed recently. So you will use screws to "pull" the rotors. That means you wont feel that the e brake shoes are hanging on to the inside and getting pulled along until the bind it all up. I did this about a week ago while redoing my axle seals and bearings. It turned out i bent the little pin that looks like a bent nail and hold the shoe tight to the axle assembly. When i say i bent it what actuall happens is i stretched it out. It has a bend in it from the factory and i "straightened it out". So it was longer after i "brent" it. The problem with that is it will not do its job and hold the shoes tight to the backing plate. They will float and move and drop the retaining spring. It is possible that this started my problems and made a small uneven spot on my brake shoe. Regardless, watch these parts when removing the rear rotors. Als if other previous owners were bone heads like i am it would be easy for them to mangle the little retaining pin. Just take a look at them next time you are in there, it is a cheap little part.
