I'm midway through my AC rebuild... My compressor seemed to be going out so I decided to replace everything but the lines. When I ordered, the Denso evaporator was out of stock almost everywhere and priced like it was made of gold where I could find it. I made the decision to try off-brand parts on it and the condenser based on some decent experiences with Chinese heat exchangers of various other types. I stuck with Denso for the compressor and expansion valve because I figured those were sensitive parts. The Nissens condenser turnout out to have a slightly smaller footprint, but fit well and actually a bunch more more coils (Is there a better term? The flattened flow tubes from one upright tube to the other), so there is actually more surface area in contact with the air. I'm thinking it's a wash at worst and possibly and upgrade.
Now, the other part that I'm actually wondering about. The GPD evaporator core is around 15% thinner: 3.5" thick vs 4.125" for the original. It's the same size in the other two dimensions and has the same coil spacing. Seems like that has to hurt efficiency, right? At the moment I'm thinking about flushing the everloving #@<& out of the original since it doesn't actually look too bad, just dirty. I've also got some foaming coil cleaner that I picked up for my household AC, so if it goes back in, it's going back clean.
Take a look at the pics... Anyone have any thoughts? I tend to start using AC about the time it's over 60ºF outside, so I want it to WORK.
). Having replaced it along with everything else, I have the coldest A/C I've had in memory. It fit fine and I'm not losing any sleep over it.
