- Joined
- Oct 7, 2006
- Threads
- 32
- Messages
- 92
I have seen the posts on how to do these, but nothing with time and
banana ratings.
I would like to compile a list of tools / job ratings / and time for these:
Assuming the engine is already out, what is the expected time for a newbie doing these?
I am planning on doing these when I have time off over the Christmas break.
Tools:
Time:
Gaskets:
Comments from Mud:
The engine can be left on the frame. https://forum.ih8mud.com/showthread.php?t=119347&highlight=rear+main+seal
The rear main seal is usually done in conjunction with changing out the clutch.
Drain OIL!!
Probably to let most of the oil drain off things so you're not under there bathing in raining oil.
If for any reason you seperate the transmission and the motor, you should replace the main seal. Toyota still carries it, but it's fairly expensive-near $40 as I recall. I thought the R and R was pretty easy-just grease it up, position carefully and drive it in. In the same area is the cam plug which can also leak. The only time you have access to that plug is when the bell housing is off. Based on my limited experience, though, if you do the oil pan gasket well, it will solve your problems. Tip-after it is spotlessly clean, clean the sealing surface with brake cleaner, and use extra Permatex in the corners.
[FONT="]Rear main seals are a breeze and zero risk of damaging them if you install them when you have the pan down....drop the rear main bearing cap, pull out the old seal, clean the area up, install the new seal, re-install the main cap, and torque the four bolts.! No hammer, no beating on a 30 dollar seal, in and out.
[/FONT]
Oil Pan Gasket
Tools:
Time:
Gaskets: 12151-61010 Toyota one-piece oil pan gasket part number
Comments from Mud:
See Poser's Thread
How should the gasket be removed?
Flat tip screwdriver
Glueing the Gasket
Glue the gasket to the block
Gaket Sealer
For the oilpan, I put RTV black in the corners, as the FSM says to do. Also four long bolt are nice to get in the four corners of the pan so you can line it up and get the shorter bolts started, the change them out once you've got the cover close enough.
Line up Gasket
!!Make sure your gasket lines up in the grooves at the front and rear of the pan!! Tighten the bolts gradually in a circular pattern from the center. Torque the bolts to 53-104 inch pounds, as per the FSM.
Retorque
Don't forget to go back a week or so later and re-torque the bolts, as they tend to loosen a bit as the gasket seats and is heated and cooled a few times.
As far as the rear main seal goes, check the flywheel for oil streaks radiating from the center, also, the rear part of the oilpan can leak into the flywheel cover, so the amount of oil in the flywheel cover isn't necessarily a good indication of the condition of the rear main seal.
Intake and Exhaust Gaskets
Tools:
Time:
Gaskets:
Comments from Mud:
Timing Cover Plate
Tools:
Time:
Gaskets:
Comments from Mud:
Head Gasket
Tools:
Time:
Gaskets:
Comments from Mud:
2F Head cover gasket
Tools:
Time:
Gaskets:
Comments from Mud:
Valve Cover Gasket
Tools:
Time:
Gaskets:
Comments from Mud:
Carburetor Rebuild
Tools:
Time:
Gaskets:
Comments from Mud:
banana ratings.I would like to compile a list of tools / job ratings / and time for these:
- Rear Main Seal
- Oil Pan Gasket
- Intake and Exhaust Gaskets
- Timing Cover Plate
- Head Gasket
- 2F Head cover gasket
- Valve Cover Gasket
- Carburetor Rebuild
Tools:
Time:
Gaskets:
Comments from Mud:
Drain OIL!!
[/FONT]
Oil Pan Gasket
Tools:
Time:
Comments from Mud:
See Poser's Thread
Glueing the Gasket
Gaket Sealer
Line up Gasket
Retorque
Tools:
Time:
Gaskets:
Comments from Mud:
Timing Cover Plate
Tools:
Time:
Gaskets:
Comments from Mud:
Head Gasket
Tools:
Time:
Gaskets:
Comments from Mud:
Tools:
Time:
Gaskets:
Comments from Mud:
Valve Cover Gasket
Tools:
Time:
Gaskets:
Comments from Mud:
Carburetor Rebuild
Tools:
Time:
Gaskets:
Comments from Mud:
