Engine Trouble
Greetings,
'79 FJ40 Stock 2F
Went for a 5 mile drive tonight - everything was fine beside the dieseling that I'm dealing with. On the way home I suddenly lost almost all power and had had to keep the pedal to the floor but was able to limp home. I can get it to start in the drive but can't maintain idle. The video below is with the choke all the way out and pedal down. It's doing this cyclic idling pattern then will eventually die.
It's hard for me to see if there's fuel in the carb sight-glass because I'm parked on a slight downgrade.
Before this I changed / gapped all spark plugs, took off the distributor cap and clean/checked the air gap, new OEM fuel filter.
Any advice on where to start would be greatly appreciated.
Check you fuel cut off solenoid to see if it is working.
will do - I had checked it a few days ago when trying to stop the dieseling and it was clicking. I'll recheck it. Starting to wonder if it could be a fuel pump issue. looks pretty new though.
Clicking does not always mean its working. Are the orings good on it? Try to jumper power to it directly from the battery and start it to see if there is a difference. You could have a electrical issue to it as well.
Could be a blocked primary main jet.
If it's an aisan, the 14mm plug bottom left of the sight glass can be removed and a long thin piece of wire [like wire brush thin] to unblock the jet often does the trick.
If it's an aisan, the 14mm plug bottom left of the sight glass can be removed and a long thin piece of wire to unblock the jet often does the trick.
Will definitely try that, thank you.
Yes think so. Snugged all three screws, didn’t want to crack it.
Sorry, forget the dissy- I replied to the wrong thread. :rolleyes:
Does your carb fuel inlet have a small screen in it? Is it clogged?
Edit: a few more thoughts:
1. Idle solenoid (as suggested above)
2. Check for vacuum leak... especially around the carb base
3. Just because the fuel pump looks new...
A. pull your dipstick and sniff it... make sure you can't smell fuel on it.
B. Make sure your pump is pumping sufficient fuel... see @Pin_head’s simple test, in the second post of this thread. Edit: In fact that whole Pin_head post may prove pertinent to your situation.
Thank you -
I disconnected the fuel line to the carb and cranked - seemed like it got about the 1 cup output in 15 sec.
I’m not seeing any fuel spray down when My kid is pumping the pedal. Clogged primary jet?
About to take off the carb and look.
Appreciate all the advice.
No fuel spray is nothing to do with primary jet. The thin wire trick can be done without removing the carb. Takes about 5 mins. If you get no response until 3/4 or more throttle it's likely a clogged primary jet. Your secondary jet is allowing you to drive only with near full throttle. Happened to me a few times,
Good luck.
Good luck.
No fuel spray in the carb with a good pump must be indicative of a clog somewhere in the carb though?
Appreciate your advice
Could be. The wire trick is something to try as a process of elimination. The blocked jet is a possibility, but not definite.
After the jet clean, cleaning out the fuel cut solenoid would be my next guess. Ideally The sight glass level should be checked first.
If still no joy it could be needle seat issue or some other blockage. Then it's time to pull apart the carb.
I always try to avoid the last part if possible.
Also if you aren't getting fuel to the sight glass, a few sharp knocks to the carb with a spanner can sometimes free up a stuck needle.
I decided to pull of the carb. The whole thing looks filthy outside and in and could use a rebuild I'm sure.
Would it be advisable to replace the manifold gasket while I have it off? I'm a novice but up for the challenge.
Uh oh, the ol' "while your in there" problem...
If you have reason to suspect that gasket, sure, replace it. But first, research WHICH gasket(s) you want to use, There may be some debate about that. You may also want to replace some of (or all of) those manifold studs washers and nuts, while your in there...
Thank you -
I've watched through the videos that @Pin_Head put up - really great information.
I think that the remflex gasket is what I'm going to go with. Sounds like it has a bit of compliance if the manifold isn't totally flat.
It seems common to replace the studs when doing the manifold gasket - why is that?
This is this one I found from another thread:
Amazon product ASIN B00B2HMHQU
Is this where the intake would typically crack? I don't see anything - yet.
I tried the Remflex gasket once, did not work well for me. Went back to 2 Fel-Pro gaskets (I run headers).
Those studs and nuts can strip or break, more so with the smaller studs on the F engine, but good to have spares on hand.
I think I need to check myself a second.
I’m assuming the manifold gasket is leaking, and it probably is l but I can’t confirm. The edge of the gasket that I can see looks like crap. Before I delve into it I’m going to replace all my vacuum lines and rebuild the carb.
As much of a pain as it is to get the carb off and on, it seems like a smaller job than removing all the stuff I need to remove in order to get to the manifold on this smogged engine.
