Engine Temp
Michigan
So I did a cat back exaust , I kept 1 magnaflow cat ,flowmaster 50 mufler 2 1/2 pipe split into 2 at the axle. It seems like the engine temp has droped about 5 degrees when I check my tourqe pro .can anyone confurm this?
Can't confirm the engine temp but I'm interested in a sound demo of that flow master.
working on it , its very mellow at ide and cruise sounds like a sports car (not a ricer ) at wot. I had a magnaflow on but the inside noise was to loud .
And there is no drone inside the cab? Sounds pretty good outside. I would prefer just one tail pipe and wonder how that may sound different.
no cruising drone but you can here it when hitting the gas hard , I would say a single pipe would be less loud but I wanted to try dual since I was doing the work .
also using my torque pro app HP went from 118 to 151 and Torque 239 to 259 . I feel that even if those numbers are not real world they do show some improvement alone with the engine temp being lower. my stock exaust must have been bad .
