Engine suddenly died while driving
central Ohio
Changed my oil yesterday, about a mile into my drive today and it suddenly dies. Coast into a driveway and pop the hood expecting a blown EFI fuse (hoping to use @NLXTACY 's electrical goodies) but everything was fine. Found this... Just wanted to post it so others learn from my mistake. Be careful when removing the oil filter as I must have put some pressure on this wire to make it loose. Glad it was an easy one as it was snowing with high winds.
I can't even tell what that is. If you were able to disconnect without pushing on the tab then make sure both sides of the tabs aren't broken.
High tension lead, coil to distributor. I disconnect it at the coil and move it out of the way when I change the oil filter if working from above. FWIW.
Correct, it is the high tension lead, just posted it as more of an informative post instead of asking a question but disconnecting it is the answer. Thanks Kernal. Apparently I just put the right amount of force in the wrong direction to pop it loose. Snapped right back in as the connector is not broke. If it only helps one person it was worth the post.
