Engine Stalling
So in Moab my engine stalled once on Hells Revenge and twice on Fins and Things. It would happen when i would start to go over an obstacle. But in Varying steepness and difficulty. SO does anyone know why this happened and how to prevent it from happening again? ( i stalled on a hill and rolled back into a tree)
Thank you!
In case folks where wondering, ROD is Romer's Other Daughter. Be nice and a search did not reveal anything. On my way to Australia now, so would appreciate some things to check.
My guess is fuel related and I recently changed the PCV valve. No issues on the highway
It could possibly be the engine wiring harness where it passes by the EGR pipe on the intake manifold. There could be an exposed wire and when the engine torques just right it grounds the wire. I have seen this before.
Thank you....i will sick daddy on it
I've had that problem, but it only caused the engine to run roughly for second, not shut off.
Let us know how it turns out.
Edit: does it not throw a code when that happens?
Hi Sara!
I was in the truck directly behind you when your engine stalled on HR. I didn't see the 2 stalls on Fins, but your stall on Hells seemed to be one of those things that can happen when you're struggling up a big rock. Mine did the same thing on Saturday on the last steep climb at the end of Fins.
It will get your attention when you loose the power brakes and steering in a 6,000# vehicle on a steep incline. You should know to get HARD on the brakes (really, really HARD) if this ever happens again. I'm talking both feet on the brake pedal and press down like you're trying to rip the steering wheel out of the dash. You and your Dad need to practice this so you feel comfortable that you can control the vehicle and get it restarted. Panic tends to set in when you are rolling backwards down a big rock with no control of the truck. :D
As far as the problem (if there is one) then I would start with the fuel filter.
-B-
In the case of Ali's rig we were ale to pull on the harness and get it to cut out.
