Engine running hotter after installing LightForce 240 Blitz
Between pixels
My engine temps have always been between 82C and 88C year round until I installed my ARB bumper and my LightForce 240 Blitz lights. Now temps are getting as high as 100C at low speed 30-50 kph when climbing hills even though the ambient isn't that warm (less than 25C). Has anyone else noticed similar findings after installing these lights on their ARB? I'm now thinking the lights have to go as they are blocking too much of the area in front of the rad.
I think it's a fairly common side effect of blocking the rad on these trucks, nothing unusual.
I saw someone else post about this not too long ago. They asked about it, people said "take your lights off and check again", he did and the temps stayed high. I believe his fan clutch needed replaced or rebuilt or something. It happened to be a coincidence in his case, IIRC.
I know @SUMMIT CRUISERS Jr has these lights on his rig and don't think he has any problems. But he upgraded his fan clutch and runs the incomparable 3FE! :)
He's got a snorkel tho
I had the same findings once I installed my 240's truck always ran 10-15f hotter as per the scan gauge. Took them off and left the ARB and temp back to normal.
looking at the pic, it seems that the rad would have had to be a good bit oversize to begin with not to see any difference with that kind of blockage. Maybe Toyota did that for reliability's sake. Maybe not...
Before I had the bumper and Light Force 240s, I had hood vents, 15K cst fluid in the fan clutch, and an electronic fan in front of the radiator. I don't have an exact gauge, but I have never seen the temp gauge go above half way with the fan on. I hardly use it in day to day driving though.
have you tried removing them?
btw...I have the same lights on mine and have noticed no negative effects...
I would guess your fan clutch performance is questionable and by adding the 240's the temps increased. If you haven't done so, which I'm thinking you haven't, upgrade your fan clutch fluid to 15k CST or higher and all should be good.
Finally removed them yesterday as it has been consistently 90F plus now for a month and my temps have been as high as 110C (230F). Noticed a huge difference right away. Max temp was 94C (201F) and it was 34C (93F) in town, and 31C when I got home. Bought some clutch fluid at a hobby store last week, but I purchased 6000 cSt fluid after reading/watching something on YouTube. What is the correct viscosity?
Unsure where I saw it, there was a guy who had overheating problems after fitting large lamps, but I guess he did not put two and two together straight away, perhaps he did it during winter? He pulled the lamps off and there was two big circles shaded in the rad where they had blocked the airflow.
Given that these cars can heat up with just some of the foam missing from the surround, if you refitted the lamps and perhaps fit a powerful enough fan you could pull the air around them?
Regards
Dave
Fans should not be required at hwy speeds to keep an engine cool. On the 80 series that does not seem to be the case. Issue is fitting a fan large enough to pull air around a bull bar, winch and big lights is a chore.
I ended up selling my 240 blitz and have none right now no issue at all with air flow now.
Most vehicles do not need a fan at highway speeds however, the 80 is one of those vehicles that do. Going by the testing I have done on hot days, the stock 80 stays cool until around 60 MPH, YMMV but, it is depending on work load/temp/tune/packing around radiator, much faster say circa 80 MPH and you will be surprised that the VC fan is actually needed. I don't use a VC controlled fan and am all electric but, I have modified the temperature gauge as per 93-97 Coolant Temperature Gauge Modification to show real temperature change, I also use LED's to tell me when the fan comes on, as the switches have been tested I know exactly when the fan comes on and goes off, your VC will respond accordingly so you would not know it is actually working.
regards
Dave
