Engine Oil Level wierd issues - need advice
While I don't doubt your math, isn't it safe to assume that when hot/warm (due to the motor running) that there would be a sizable amount of oil still above the pan, in the head, motor etc. that hasn't drained back to the pan to be measured?
Yes, I'd say "some" rather than "sizable" but anyways, please refer to post 11 above. Thanks. Post 19 was simply to CJF's point that expansion through higher temps wasn't "noticeable". Cheers.
Gotcha, missed that one....what do you think?.....sub-quart?
For what it's worth, I let the idiot light flicker for a while until it stays on relatively constantly, then I check the dipstick while the truck is on flat ground, cold and add as needed. Using the light as early warning system not to be simply trusted by itself...
I'd gander a guess that it is less than a half a quart of suspended oil within about one minute of draining down (not including the oil filter). I really would recommend checking and filling with a warm engine though. Hope that helps. :cheers:
The only time my rig does what the OP is describing is when I'm about a quart low, the light is more likely to come on when the engine is cold. Maybe check to see that the oil dipstick is the correct length?? IDK.
Well for some reason truck stopped doing it so I am not sure what to think of whole thing :bang:
I just need to keep it running until snow stops. Then I will drop oil pan and check oil level sensor itself. I think thats the problem I have.
My light will start doing that every 2-3 thousand miles. I add a half quart and I'm good. This is typical and nothing to be concerned about. Try adding half a quart and see if the same thing happens on the same hill.
Red Tacoma: last year I had a mechanics misadventure and busted both my oil pans so had to get new pans and a new oil level sensor. The plastic float of the old/original oil level sensor was broken probably from the accident but seemed fragile and may have broken more easily due to age. Suggest you be careful when pulling your sensor out; IIRC the list price for a new OEM part is around $400.
Red Tacoma: last year I had a mechanics misadventure and busted both my oil pans so had to get new pans and a new oil level sensor. The plastic float of the old/original oil level sensor was broken probably from the accident, but it was very fragile and may have been broken just due to age. Suggest you be careful when pulling your sensor out; IIRC the list price new OEM is around $400.
You removed sensor before pulling oil pans apart right or after? Yeah $400 would suck but if I brake it not going have choice :doh::)
I didn't do the work, it was covered under my collision insurance so had it towed to the dealer, not sure if the mechanic took it out before or after dropping the pans. The float was half broken, then when I fiddled with it the rest fell off. Maybe the float gets fragile after sitting in hot oil for many years??
When removing the pan I left the sensor in place and simply unplugged it, why make more work?
regards
Dave
I though sensor needs to be removed otherwise pan will not clear the engine , sensor and that tube under the engine...
nope straight out no probs!
regards
Dave
Must have missed this post the day it dropped in but technically the volumetric coefficient of expansion of motor oil (per 1degree F) is .00039 or .0004 rounded. So for a 120 degree F change in our motor oil temp we would get approximately a 4.8% increase in volume. On an 8 quart system that would be a bit less than 1/2 a quart (.384 quarts) and you should definitely see that difference on the dipstick. That is one reason why most manufacturers recommend testing the oil level with engine warmed up. Obviously the higher the temp the higher the expansion. Hope that helps. :cheers:
How much does the oil container volume change as a result of thermal expansion? Oil sump pan and engine block also expand too, which should not be neglected in the equation. The oil volume increases with temperature, but so does the container that holds it :hhmm:
Ok so my 94 has this weird issue, when I drive up the hill holding RPMS at 2500 for a minute or so, my oil level light comes on.
On flat ground I checked oil level and it was at exact F mark.
oil pressure is good ... at 2500 RPMS shows 3/4 steady and at idle shows little (1 mm) less then a 1/4. Level thing happens more often when truck is not at the full temperature.
My oil is Rotella 5w-40.
So questions are.
1. Anybody had similiar issues and can give me a pointers what to check?
2. Is it possible for oil to "hide" somewhere in the engine in the engine and not come back to oil pan?
3. Is there a good way to check if oil level sensor is bad and its out of alignment?
Thanks
RedTacoma:
For what it's worth, I drove my '94 80 (original owner) for 238,000 miles and I used Mobil 1 15-50 Syn year round. I talked to my buddy who is a Toyota Master Mechanic and he told me the engine galleys and oil drain holes are plenty sufficient for the thicker oil to drain back to the pan in a timely enough fashion. He indicated that the newer engines would not tolerate this and would cause starvation if you didn't use the 0W - 30, but not our truck engines.
By the way, I am in the Midwest and we have plenty of zero degree F weather, and no issues due to the viscosity. Given his comments, I would suspect that any "debris" would have plenty of clearance to return to the oil pan without restricting flow. I've always used Toyota oil filters however due to their quality. Have you tried going back to OEM on the filter to see what happens?
My truck is doing the same thing and I am running 15/40 so I am just ticking it up to a little bit of everything. A little low on oil and the cold staying at the top of the motor. Pressure is excellent like the 3rd line up. So I poured some lucas in it and went on. Just gonna ignore it.
My '97 FZJ is doing the exact same thing! Only when it is cold and only for about a minute after I start it up and start driving. Just like the quoted post below. Pressure gauge has been in the "normal range" every time and the oil level is also within normal limits. I guess I will try to change oil viscosity and see what happens. I'm running 5W30 right now. Any follow ups on this since the flurry of traffic in 2011?
My '97 used to do the same thing running 5w-30 oil. After a cold start 2 miles from my house the light would come on like clock work. Switched to 10w-30 oil and the light went away.
Still no light after changing to 10w30.:bounce:
