Engine Oil Level wierd issues - need advice
Ok so my 94 has this weird issue, when I drive up the hill holding RPMS at 2500 for a minute or so, my oil level light comes on.
On flat ground I checked oil level and it was at exact F mark.
oil pressure is good ... at 2500 RPMS shows 3/4 steady and at idle shows little (1 mm) less then a 1/4. Level thing happens more often when truck is not at the full temperature.
My oil is Rotella 5w-40.
So questions are.
1. Anybody had similiar issues and can give me a pointers what to check?
2. Is it possible for oil to "hide" somewhere in the engine in the engine and not come back to oil pan?
3. Is there a good way to check if oil level sensor is bad and its out of alignment?
Thanks
Yes I checked oil level per manual, even cold after a few hours and still dip stick is showing full np.
Its only Oil Level light "yellow with oil can and squigly thing" that comes off from time to time. And it does that only when driving up the hill. I can run engine at 2500 RPMS parked on level ground and no issue. its like oil gets pumped, but because engine is in angle, it does not drain back to oil pan. Very strange. :hhmm:
I am baffled, and sort of concern I may ruin something.
Is there a bypass valve that is located behind oil pressure gauge?
If bypass was open it would allow pump to pump all oil out somewhere else. But The only place that could hold oil I would think would be on the top under the valve cover.
To be sure you could drain the oil and see if you have about 8 qts.
As far as I remember this is a pretty common phenomenon and I know that for a while I was seeing the same thing on my rig (with slightly different settings on RPM than you told us about here) for a few seconds at a time and especially as engine was warming up but I basically ran through all the same things and ruled out repairing anything. As a coincidence since I started running Mobil 1 5w40 year-round instead of 0w40 in the winter and 5w40 in the summer I haven't seen the light. I say "coincidence" because I'm not saying the 5w40 was the fix for this just that I haven't seen it since I started only running on 5w40 (about the last two years IIRC).
Anyways, I'd say that as long as the low oil light is only on for a few seconds, and as long as the oil pressure is in the right range, you are probably fine provided you really do have the right amount of oil. Next time you see this situation try to take your eye off the light there and look at the oil pressure gauge to confirm that its in the right range. If you have any doubts about the oil pressure gauge on the dash put an actual gauge on the engine to confirm that the pump is pressurizing the system. Other than that even though this is truly out of character for me, I'd say, don't worry with it. :D
:cheers:
My '97 used to do the same thing running 5w-30 oil. After a cold start 2 miles from my house the light would come on like clock work. Switched to 10w-30 oil and the light went away.
Yeah Oil pressure guage seems to be OK, and it is showing constant good pressure.
I hear you on oil type thats something I am considering. I did read somewhere that Rotella 5W-40 is very thick at cold but I would never imagine its so thick that oil does not flow back to oil pan. I am wondering if K&N filter has anything to do with it. Its that over sized big filter that supposed to have good flow at low RPMS so it probably puts very little back pressure on the pump allowing more volume to flow through it. ?:hhmm:
I can live with that but would like to find source of the problem and fix it.
Yes on the 8qt of oil (actually more like 9)
Thanks for the input. Now any idea how to check where this oil "hangs"?
Not to hi-jack Red Tacomas thread, but I have a question about running thicker oil in the winter. I never changed weights and still have my 15W-40 Rotella in. I always show about half way to one quarter of the way on the hatch marks when I check my oil. Even going by the FSM guidelines. It isn't burning oil. Could this be due to the oil being so thick it hangs up inside the engine and is there any negative side affects to this?
Thanks
Oil level gets higher as the vehicle sits and the engine cools.
Actually, it gets "higher" as the rig sits due to the dropping of suspended oil into the pan but it gets "lower" as the oil cools and contracts. Just FYI in the hope it helps. :cheers:
My cruiser does the same thing. Oil pressure according to the gauge remains excellent, but every once in a while the low oil light comes on for a few seconds. Nothing about the oil pressure changes, still good. Then once it reaches temperature it does not come on again. The dipstick is right in range.
I just bought the rig, and I have not changed the oil yet. The po was running 10w30, probably something cheap based on the autozone window sticker. I plan on running amsoil full synthetic, 5w30 when I change it.
For what it is worth, as long as my oil pressure is as good as it is, I am content to disregard the occasional oil light.
Just my .02.
Happens to me all the time after one particular hill. The gauge is VERY sensitive and these rigs all burn just a bit of oil on cold starts. It will get progressively more frequent (the light illuminating) as the cold starts burn a bit more off. just throw a quart in there and call it good.
This thing bugs me. So level checks and everything reveal no problems, idling in place at higher RPMS no problem. Its Up the hill driving on cold. :censor:
One thing why my truck was not doing it before and suddenly after bunch of work done this year when winter came I have that issue :hhmm:
Is there a oil channel on the back of the engine that could be clogged? That would stop oil from draining to oil pan right ?
These may help...
Ok, so mine just started doing this too, but it stays on for more extended periods (5-10 minutes some times). The oil pressure stays up, so I keep driving, but it's still quite bothersome. I'm running 10w-30, and was thinking of trying 5w-30, but after arndog123 said it was worse on the 5w-30, i'm rethinking. I wonder if maybe a low quality filter flows too much and in turn drains the sump?? I'm on a carquest filter, what are others running??
The sump and filter hold 8+ quarts of oil. The light will start to come on in most trucks when it's a quart low. I have personal experience with my truck going down to a total of 2 quarts of oil in the engine without it immediately seizing up. If the oil light is flickering and your dipstick says it's full, ignore the light.
Oh and BTW, don't trust the light to tell you when it's low. :o
Theoretically? yes; of course.
Noticeably? I doubt it.
Must have missed this post the day it dropped in but technically the volumetric coefficient of expansion of motor oil (per 1degree F) is .00039 or .0004 rounded. So for a 120 degree F change in our motor oil temp we would get approximately a 4.8% increase in volume. On an 8 quart system that would be a bit less than 1/2 a quart (.384 quarts) and you should definitely see that difference on the dipstick. That is one reason why most manufacturers recommend testing the oil level with engine warmed up. Obviously the higher the temp the higher the expansion. Hope that helps. :cheers:
While I don't doubt your math, isn't it safe to assume that when hot/warm (due to the motor running) that there would be a sizable amount of oil still above the pan, in the head, motor etc. that hasn't drained back to the pan to be measured?
