engine oil leak - simple fix
Sunnyvale, CA
Website
www.george4wd.taskled.com
So, our 80 started dripping oil at the rear of the engine - wtf - this isn't some pos LR gear.
Anyhow, being winter in the Bay Area and having as my wife states "thin aussie blood", it was way too cold to go looking for leaks - couple of fresh drops each time the 80 was parked back on the driveway.
Then 2 week ago it was time to get ready for a camping trip with the kids, so was doing the standard under the bonnet checks and figured it couldn't hurt to put a socket on the rocker cover bolts. Ah - rear 1/2 of the PS was fairly loose and the rear most PS was finger tight. Tighten them all up again, spray de-greaser on the rear engine and wash off the oil & crud and after 1 week back in town not a single drip on the driveway.
Just something to check on your 80 and a simple way to exorcise any LR demons that are lingering nearby that feed on oil leaks (neighbour across the street had an LR2 for a while).
cheers,
george.
What and where is the rear cover bolts?
I guess it's called a valve cover in the US...
cheers,
george.
x2- what are the rocker cover bolts? I'm sure it will make sense once you explain it... :idea:
:steer:
Edit- I'm slow...
That ended up being my problem .. don't torque to hard though. I think I crushed the gasket and now it leaks even worse! Gotta dig in next week once my parts come in from Dan.
just did the same yesterday after swapping my dizzy oring. Mine were finger tight as well. Two big leaks that were spotting the driveway and smelling bad when the engine got hot. Hope I get the same results as you.
... so was doing the standard under the bonnet checks and figured it couldn't hurt to put a socket on the rocker cover bolts. Ah - rear 1/2 of the PS was fairly loose and the rear most PS was finger tight. Tighten them all up again, spray de-greaser on the rear engine and wash off the oil & crud and after 1 week back in town not a single drip on the driveway.
cheers,
george.
I went under the engine on Sunday to see if maybe this was the reason for my small, but irritating oil leak. I checked some and all were tight except two. But I´m not sure which are the ones you guys are referring to :confused:
Any chance of posting a pic whenever you get a chance?? I would greatly appreciate and it would surely help :)
Could someone post a pic of these rocker / valve cover bolts and their location?? Not sure they are the ones I´m thinking. Would greatly appreciate it.
Just get in there and start tightening anything that's loose! Ha.
