Hi guys,
Having a problem with the idle of my 97' 1fzfe.
Slowly been creeping up to 1000/1200rpm hot and cold. Then for some reason after driving on the highway I noticed it was idling at 1600/1800!
So checked the following;
-vacuum hoses for leaks
-air intake hose for splits
-iac valve - cleaned it and can hear it working
-tps cleaned and seems ok
-maf recently cleaned
-cables and linkages all seem good
-taken the a/c belt off to check - same problem
Wondering if valves that need adjustment would cause this problem? Last checked them 30k km ago and a few were near the upper and lower tolerances.
Can't seem to find a big brass screw by the efi unit that I've seen mentioned causing idle issues.
Going to do the fault code sequence as described in fsm.
As always any input appreciated!
