Engine experts - odd issue with setting the valves.
Hurricane WV
I looked around cant seem to find any threads on my current valve issue.
1979 FJ40 2 F motor - ran decent with no known issues except I had to replace the gas tank due to rust. Do to the rust in the tank we decided to clean the carb well so while it was off thought it would be worth checking the valves.
We attempted to set the valves several times and they will not stay in spec.
Here is what is happened (sorry I may not have the best description)
Turn the fly wheel to the TDC marking on the fly wheel in the viewing window.
Now we set the valves following this chart (We are doing them COLD)
Once we did the yellow, we rolled the motor around to the TDC line and then did the pink valves.
Roll the motor 1 revolution to TDC and check the yellow - Valves are off (normally #3-9). The one was over 6 thoundsant loose.
Roll the motor again to check pink, again 1 or 2 substantially out of spec.
Roll the motor again 1 revolution and not the one that was 6 thoundsant off is now back in spec.
We have done this several times with the same results over and over. I understand that normally you sent the valves, roll the motor over and one or two may be a hair off so you reset them. Then mostly they stay in spec and your done. I can not get them to stay in spec.
After the first try with these results, we pulled the center tube with all the rockers and cleaned everything, making sure they all move freely. We put it back on and torqued every bolt at least three times following the pattern listed in the manual to make sure they were dead on.
That is when we reset the valves and again had the above results.
I did find one slightly loose stud that was also bent a bit but replaced it.
I am looking for any info on what could be causing this or what we are missing/doing wrong. As I mentioned, it ran okay, but when we checked the valves, a few were good and tight, so we figured no big deal, just set them and have been going in circles ever since.
Thank you
Have you tried setting the valves while its idling? Look at the adjustment and lock nut threads - some people wrench that down like it is Jesus nut on a helicopter main rotor - stretched threads can cause issues.
I like my valves set on the loose end of clearance, better to hear them than burn them. I do them in firing order not the method you use. All plugs out, and only pulling on the metal fan to position the piston - no turning the engine backwards.
Give it a good hard Italian tune up before adjusting things. What are the compression #'s
Were you on TDC on the compression stroke when you started adjusting the yellow valves?
I’ve never used that table, I’ve seen it, I just prefer to do #1 at TDC (watch the. Intake valve fully close plus a little). And just go through the timing order the same way ; 45 years 🙄 (from my original factory F engine manual).
They should not change, and even with worn cam lobes I would not expect changes; I have to assume your using the table wrong and are starting or ending 180 deg. out (remember two flywheel revolutions to get back to TDC). Just do it the old factory service manual way, and see if that solves it.
I've always set mine with the engine idling. My step dad taught me that way on my '76 40 when I was 16 back in '85 and I've been adjusting them that way on 2Fs ever since: .008" intake, .014" exhaust. I never even look them up anymore.
That's why there are 'hot' and 'cold' numbers I believe. Hot for running, cold for not.
When I ran a stk 6 cyldr I never set valves using a chart like that or have it running. I always would adjust going thru the firing order. Back in the day i would adjusted the hydraulic lifters on a sbc while it was running. What a mess. Later I figured there has to be a better way. The factory wouldn't do it this way. Then I found a similar chart for a Chev V8 or I'll just go thru the firing order starting with #1 cyldr at tdc on the compression stroke then rotate the crank every 90* to adjust the next cyldr in line.
A worn cam isn't going to make the gap change thru each revolution of a solid lifter cam on the compression stroke. The gap should remain constant regardless.
Thank you
I had a similar experience with my resurrected 79 2F recently, after putting around 5k on the road, so I'm curious what you come up with.
I adjusted valves cold using that handy chart, several times getting inconsistent results on several valves each time I turned the crank. Not a huge difference, maybe a couple thousandth, but enough that I noticed.
So, I tried the running method, thinking I should be around .002" tighter when hot. Again, inconsistencies vs the cold method on some valves. And, I did a number on my .008" feeler gauge.
In order to get it back on the road, I got as close as I could, being careful not to run any too tight. I'll try it again and take better notes when I have more time.
Perhaps coincidentally, my compression checks done at the same time were also a bit inconsistent.
I never know if these things are tool-related, skill-level related, or worn parts related, so I'm kinda used to inconsistent or unexplained results and move on.
About the "worn parts related" angle, there are several components that make up and add up to a specific tappet gap (cam lobes, lifter surface, uneven rocker/valve surfaces, etc). My 79 most likely has some or all of those factors.
Still, I am very curious what you find.
I have not got compressioin numbers yet, but we can do that.
We did not try it ideling as the carb is still off, and figured it should be simular to cold, just slightly difference clearances. Would that make a difference?
Everyone says it should never float in and out of spec, but it sure does. Ugh
Yes Sir.
Maybe we can pull the pan and see if we notice anything, I have a new gasket to install anyway.....
Thanks for the ideas and if anyone has anything to add, please do!
I talked to an old guy, engine machinist today about what might cause inconsistent results when adjusting valves on a solid lifter engine like the 2F.
Since a solid lifter is supposed to rotate upon each pass of the cam lobe, if there is uneven wear on the solid lifter face, it's possible to get different readings when turning the crank/cam.
Also, to avoid any inconsistent, worn cam involvement, he suggested not using the two-pass, easy method (at TDC, adjust half the valves, then rotate the crank 360° and adjust the other half).
Similar to some of the other methods mentioned above, he rotates the crank and watches each valve get to max compression, then adjusts the other valve for that cylinder. That way the valve being adjusted is definitely at the base of the cam, not on the side somewhere.
It's probably much easier for him with the engine on a stand, but I'm going to try it next time and see if my results are more consistent.
You might try using a degree wheel for accuracy. Once you've adjusted #1 cylinder on top dead center on the compression stroke, now you can rotate the crank 120 degrees and adjust the next cylinder in the firing order, it will be on its tdc on its compression stroke. Then do this 4 more times. If its a 8 cylinder rotate 90*, a 4 cylinder 180*. It's probably tuff to get the wheel attached to the Toyota balancer though.
I think your friend is onto something. Today we pulled the side cover and the lifters. The valves that were really going out of spec, the lifters have what I would call a dent. They are NOT perfectly smooth and you can feel the indentation. 12 new ones have been ordered.
I checked the cam with a camera and by putting my finger in the hole and feeling it. I cannot feel any lines, or indentations but am still thinking I may need to order a new one and start fresh. I’m a bit scared to use the old one at this point.
I also did a compression test (results below). The two 120 reads are on the cylinders with the BAD lifters. I am hoping the numbers improve once I get that corrected.
I'm glad you found something that may solve the mystery.
It's kinda funny, my 79 not only seems to have the same issue wrt valve adjustments, but I also replaced a couple of lifters 5k miles ago, around #4 cylinder as I recall. And my compression numbers seem similar as well.
About replacing lifters and cam, that machine shop guy I spoke with today indicated he's had some bad luck (premature wear) with those aftermarket parts. He suggested, if mine are OEM, I should have both the cam and lifters reground instead. I've read similar comments here and heard that there's an outfit in Washington state (Delta?) that does a good job on cams. That's probably the way I'll go if I ever get to "phase 2" on my project.
In the meantime, I'm having a lot of fun driving it, in all its worn out, rusted out glory!
Be careful, I was just adjusting valves, same as you.
Strangely enough, I couldn't get my valves adjusted correctly (wouldn't keep the correct clearance), I found my camshaft and lifters were thrashed harder than a Suicidal Tendencies and Slayer concert back in the early 90's.
I have a new cam shaft, new lifters, new oil pump, new DUI distributor, and all related gaskets coming. Going to refresh a few things while it is apart.
It does appear if you cant keep the valves in spec to look at the rockers and cam. Not what you want ot find but......
