So the other day I was out riding around in my 97 cruiser and she was running fine. I stopped to get out and wipe some mud from my boots, got back in and put her in drive and thats when the problem started. In drive the engine chokes out, if I feather the throttle I can get it up to about 20-30 mph but barely. If I put it back in park and such the accelerator the engine revs fine just like nothing is wrong. Anyone know whats going on here?
Sounds like it may be the wiring harness beside the EGR valve/tube. When it gear, the engine torques to the side a little and this small movement may be enough to cause some melted wires inside the wire bundle to either short or separate. You will have to get some new insulation wrap from someone like Jegs and peal the old stuff off and inspect for melted wires.
The second thing to check would be a worn out intake tube. When the engine does the same movement in gear, the tube may stretch a little and open up holes and let unmetered air in. This will usually throw a code. I think P0071 or 72. May also start happening after a person takes the truck to a oil change place and they bend the tube all around when they "inspect" the air filter.
Another possibility is fuel delivery, not able to keep up with a loaded engine (in Drive). Something simple as a clogged fuel filter to perhaps debris blocking the fuel pump sock filter (inside the tank).
Another possibility; if it's been wet, the connector at the TPS is not sealed (not sure why?) can get water in it. If it's wet in the connector, can cause what you are experiencing. We pack them with silicone grease.
