Engine Build and Proper Spark Plug
My apologies if this is an old question, but I would like to know the build year for my engine which seems to pre-date the published information. I would also like to know the proper OEM spark plug as I have seen lengths of 3/8, 1/2 and 3/4. Any information would be appreciated. The engine number is F 248996.
Thanks to all of you.
check here : Land Cruiser Engine Numbers
Thank you very much JohnnyC. Where is the cast stamp located on the driver's side? Where do I find info on it? You have been very helpful and it is greatly appreciated confirming the W14EXR-U plug which has the 3/4" threaded section.
Dura
Dura
I have send you a link to the thread about this ... with pictures and all explanation.
SergP,
I am sorry, but I am not smart about these things. The link with the date list only goes back to 1969 and I don't see where the other link has any info on a driver's side casting stamp. Thank you for your help.
Dura
SergP,
Dura
Ok. Not worry we all learning.
Look at this image.
first single number is Year,.. next ..600xx model, ... next Month and Day ( example here 1974.. 1.5engine .. April 22 )
in your case .. year will be 196x and different model
You don't need to remove a valves cover to see those numbers (on the left side of the block)
