Emissions test anomaly
Took our 1994 Toyota Land Cruiser for its annual emissions test. It passed the tailipipe emissions but failed on the gas cap pressure test. Drove 3 miles to a parts store, got a new cap and returned for a retest. Second test was on the same dynamometer with same technician. As you can see the results are very different. I'm pretty sure the gas cap plays no role in tailpipe emissions, just in gasoline vapor emissions. Anyone have any explanation? Emissions testing not reliable at all?
Limits:
HC--2.0
CO--20.0
NOX--4.0
Test one
HC--.7660
CO--16.5365
NOX--3.1477
Test two
HC--.4176
CO--7.6637
NOX--1.7369
Test one passes but pretty close on some numbers. Test two is clean as a whistle. Engine was at same temperature in both cases. No other differences besides a new gas cap and 6 additional miles. By the way, I've kept the old emissions tests and test 2 is far closer to the previous norms than test 1. Also the NOX limits on the first test I had done on it was 9 and it has since been reduced to 4.
could it be that the engine and especially cats were actually hotter for the second test? I always make sure my engine and cats are piping hot for the measurements.
What state are you in? In Calif they got rid of the cap test recently for some year models but apparently some techs don't know yet they are not supposed to test for it.
I'm in CO. It's hard to imagine that engine and cat conditions changed much. Drove about 7 miles to get to the first test. Drove 6 miles after first test and then did second test. Perhaps a few minutes more of idling in line before the second test.
By the way, after the test, I swapped in the old cap and will keep the new cap to install right before any future tests.
Slow, weak driving w/more idling or engine got cold the first time. 2nd time less idling, romped on it to get the cap/on the way back or engine run time longer?
Never, start up a cold engine and drive only 7 miles to get a smog test. That's just asking for it.
Newer cars can get away with that, but aging cars need all the help they can get.
Take it for a fast drive on the freeway for at least 20 minutes, then drive to the smog station, and never turn off the engine while you're waiting for the test.
The gas cap is not tested on the vehicle, but on a machine to see if it will hold pressure. Part of the EVAP test and does not effect the tailpipe numbers at all.
From what I've heard, if a car fails any portion of the test, it has to do the whole test over again the next time.
I think yout CAT & engine was hotter the 2nd time.
Your suppose to drive around for 15 min before the smog test to heat the catalytic converter to heat up and "light off". 2nd test is probably with the cat warm and working.
X2 on really getting the truck warmed up. Just got my Colorado emissions done today on my 1993 FZJ80. Drove the truck 15-20 min on the highway and didn't turn off until I handed it off for testing. My numbers were
HC - 0.7
CO-11.12
NOx-1.3
I did replace my cats two years ago, but very important that they are hot. I'm guessing the extra few miles made the difference in the numbers.
Always a nail biter if these old rigs will pass or not
