elocker double check
If it's the same locker used on Tacoma, then yes, it will fit your axle with modification. It is not a bolt in.
So I found an Elocker third member from a 2007 Fj Cruiser. Looks like it is the standard 8" diff and should fit in my first gen 4runner, right?
i'm pretty sure there are only 3 versions of the elocker, HP 8' from front of 80 series, LP 9.5 from the rear of 80 series, everything else is LP 8". the gear ratios will vary. they not hard to put in non elocker housing. Try to get the ECU and switch too, works better than relays, i've done it both ways.
I've wired up two e-lockers. No relays. No ECU. Just wire to a switch. Never had a problem.
