Continuation of Elliott's build....
Well, I am the proud new owner of Elliott's old cruiser. I have been a bit busy with work lately and have not had much time to dig into the project. I have driven it around a bit though and discovered a few more mechanical issues and have decided to tackle those first before I worry about the body or interior. Here are the issues mechanically that I know of that need working out.
1. Rattling noise coming from the driver's side, near the exhaust. --- took care of it today, was tough to locate and easy to fix; a loose blank-off plate for some smog related stuff (I think....)
2. Power steering fluid leak coming from somewhere on the low-pressure/cooling side of the lines. One of the return lines was in rough shape, so I decided to just replace all of them to heal any future issues. I was reading up on the problem and discovered that some people were just going with an aftermarket NAPA generic cooler. Didn't seem like a bad route to go, only $40 for the cooler. ---- I am in the middle of installing it right now, surprisingly enough getting the hoses on the fittings has been the toughest part. I threw a few pics in to just show the part and install. (At least I am trying, I am a bit new to this posting business)
3. There is a light tapping noise coming from under the valve covers. I think since the top-end of the motor was recently rebuilt, but not run to much be Elliott, that the heating and cooling cycles have just loosened a few things up. --- I just need to get in there and check the valve clearances and adjust if necessary. Not a big deal, I had to buy the feeler gauges though.
4. This is the problem that I am most concerned about. There was a large puddle of coolant underneath the vehicle after the last time I ran it, although it took a few days to accumulate. It is dripping from the transfer case though, not anywhere near the radiator. The only thing that i can figure is that one of the lines coming from the back of the motor near the firewall (the line behind the carb that heads back into somewhere I can't see because of a cover, probably a heat shield or something) has a small leak and just needs to be tightened down. ---- I have not really had a chance to dig deeply into this one yet, I just decided to tackle one thing at a time. Any advice would be nice.
I am not sure whether I will continue to post things on here or whether I will kind of start a different page to continue the build. Any feedback? Is anyone really interested in following the rest of the build?
Cheers,
-Caleb
Cheers,
-Caleb
