electronic ignition options
Discussion in '40- & 55-Series Tech' started by rob5182, Mar 4, 2007.
  1. rob5182
    rob5182 SILVER Star
    233
    127
    Jan 10, 2007
    Ras Tanura KSA
    Hi all,
    I have a 1976 FJ40 2F with the stock distribrutor and ignition system. The ignitor recently just went out and I need some options to get back on the road. Is there a pentronic system or other system that will work with my distributor? Should I buy a used ignitor~$300 or what is my best option for around $150.
    THANKS
    ROBERT
  2. Josie'sLandCruiser
    Josie'sLandCruiser Stop calling it a "FJ."
    5,163
    Media:
    10
    Albums:
    1
    176
    Feb 4, 2005
    Seattle, USA
    Hi All:
    Try to find a good, used Toyota fully electronic ignition (coil, distributor, etc.) from a 1978 & up Land Cruiser 40 or 55 Series. The ones that came on the later 60 Series wagons will also fit but the distributor is a bit larger in diameter.
    Good luck with your rig!
    Regards,
    Alan
  3. Trollhole
    Trollhole THC Supporting Vendor Moderator
    20,805
    Media:
    79
    Albums:
    4
    2,638
    Mar 6, 2005
    Mauldin, SC
    Small cap electronic distributor. Easy to install. Just did this. Works great.
  4. rjcruiser
    rjcruiser
    329
    5
    Feb 13, 2006
    Covington GA
    I'm not sure if pertronix will work with your year or not, but if it does, it is the best, cheapest option. I've used it several times and never been disappointed. Give Mark's offroad a call....he carries them and would be able to give you the details on what will work best.
  5. SteveO
    SteveO
    306
    Mar 2, 2006
    Calgary AB.
    I just installed a Pertronix kit from Mark's Offroad in my 77 and it works great. Installs very easily as well. ...Steve
